windows not clear
Old Oct 23, 2004 | 08:46 AM
gsopc's Avatar
Default windows not clear
I have noticed that there is a stain pattern on the glass after cleaning. Is it in the glass or do I need to clean it with a special product?
Old Oct 23, 2004 | 09:46 AM
NJspeed69's Avatar
Default Re: windows not clear
I never heard of that happening unless you used a really harsh cleaner.
Do you have your windows tinted? If you do, your supposed to only use the GENTLEST of cleaners, otherwise that could definately happen.
If none of these two scenarios fit, I'd see if the dealer could replace the window under warranty. It shouldnt scour just using regular glass cleaner. Use your fingers and feel whether the glass is rougher there, could mean it was eaten away. I've never heard of glass "staining".
Old Mar 13, 2005 | 12:16 AM
jsg28's Avatar
Do you smoke in the car? If not I use Invisable Glass its a foam and works better than any other product i have ever used....
Old Mar 13, 2005 | 11:29 PM
andrew's Avatar
-C-I-C-C-I Associate Member
try rubbing alcohol on a towel...this should do the trick.
Old Mar 14, 2005 | 09:13 AM
Dan Root's Avatar
Banned
Or just a couple shots and you won't care anymore !
Old Mar 14, 2005 | 10:44 AM
gurutek24's Avatar
Red face Re: windows not clear
Anyone here having a problem when closing the door with the window down how loud and hard the door slams?
I almost killed my little brother for slamming my door while the window was down...it sounded like it was very loose inside the door.
Old Mar 14, 2005 | 10:53 AM
NJspeed69's Avatar
My girl always SLAMS it. Then again it seems so does everyone but shes the usual passenger. I think when your in the car that the door closing feels/sounds louder than they actually are.
Old Mar 14, 2005 | 11:02 AM
gurutek24's Avatar
Cool Re: windows not clear
Thanks, I thought it was just me. I guess you have the same problem when your in the car and someone closes the trunk...my girlfriend thinks i'm upset when i close it and shes in the car...its extremly loud.
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
crossfireusa
Oct 28, 2015 12:03 AM
nataliefs
Oct 5, 2015 01:03 PM
tritongreen
Sep 18, 2015 07:32 AM
