J.j.
Old Nov 26, 2013 | 04:30 PM
J.J.'s Avatar
Default J.j.
I probably should have started on 'technical/troubleshooting' but started with 'engines/exhaust':
On this category since it's 'engines' and 'exhaust' which relate to the topic... After watching the 'check engine' light go on and off periodically for a few months, I finally went to Auto Zone to have the p-codes checked, the guy didn't know where to plug it in, usually under the dash he says. So where does it hide? Thanks!
Old Nov 26, 2013 | 04:31 PM
Mrmiata's Avatar
Default Re: J.j.
see other post..
Old Dec 5, 2013 | 01:33 PM
J.J.'s Avatar
Default Re: J.j.
Finally got to Auto Zone, got 2 codes: P0335: Definition: Crankshaft position sensor condition. Explanation: Crankshaft position sensor signal is monitored for faults. Probable cause: Crank sensor defective; Check connector and wiring to sensor; Check trigger wheel for damage. Code P0410: Definition: Secondary air injection system fault. Explanation: Air injection system is monitored for faults. Probable cause: Circuit relay defective or fuse open; Check connector and wiring; air pump defective or hoses blocked.
Assume next step is to get all these items checked out. I did have a 'relay module' replaced a few months ago when the light first came on at a small repair shop. Many thanks from a happy Crossfire owner, '04, had it 3 years.
Old Dec 5, 2013 | 01:39 PM
Default Re: J.j.
The P0410 is pretty common and usually no cause for concern
probable fault areas are :
1. the relay contacts for the air pump in the relay module
2. a defective air pump
3. wiring problems
The P0335 usually means you need to order a Bosch CPS sensor and replace it.
