6 sp trans problem
Old Oct 23, 2004 | 05:00 PM
danny d's Avatar
Default 6 sp trans problem
How can I tell if my car is covered under the TSB for the trans. I have #2513 and it has been popping out of 1st gear every now and then.
Any help would be appreciated.
Thanks
Dan
Old Oct 23, 2004 | 05:13 PM
mightyjlr's Avatar
CrossfireForum.org Founder
Default Re: 6 sp trans problem
Every car made should be covered under it. Just tell your dealership you're having the problem and they should fix it. If they don't call up Chrysler and complain.
Old Oct 23, 2004 | 05:16 PM
cgates's Avatar
Thanks
Dan
If your car is popping out of gear, take it in. With a 3 year warranty, they should fix it.
You can also check your build date, a tag on the inside drivers door. Cars with the possible 1st gear issue will have build dates prior to Dec 31, 2003.
Old Oct 23, 2004 | 05:27 PM
danny d's Avatar
Thanks... Found the date 6/03. At least now I know for sure there should be no problems at my dealer.
Thanks again!
Old Oct 23, 2004 | 05:37 PM
Dan Root's Avatar
Banned
I'd hate to see what a Supercharger would do to that 6 speed. I guess (someone) will find out.
Old Jun 4, 2005 | 01:13 PM
AlbertFattal's Avatar
Is the 6-speed really this weak?
Old Sep 27, 2005 | 07:46 PM
jmackinjersey's Avatar
I've had my syncro's replaced because it wouldn't go into 1st or 2nd gear. now it is doing the same thing as well as popping out of 1st.a lot more now than before. Mercedes put the M6 on the back burner to try and put maximum effort towards their automatics.
Old Sep 27, 2005 | 10:03 PM
dirtboy's Avatar
Take it in and tell them it pops out of first gear. Doesn't matter if there's a TSB or not, your vehicle has a defect and they'll fix it.
I've been in for the problem twice. First time was a new tranny, the second was an adjustment that they didn't want to do. I told them to do it, they claimed they didn't, but the car is much, much better now.
Old Sep 28, 2005 | 12:16 AM
TheCrossfirekid's Avatar
Does anyone have problems engaging the car into 1st and 2nd? and reverse? I have always had problems with 1st and the shift to 2nd, and now lately the car won't engage in reverse right away. But of course when i take it to the dealership the shop manager says, its the best feeling 6 speed that he has been in. He only shifted the car through the gears while it was parked. But it seems once power is going to the wheels the tranny sux.
Old Sep 28, 2005 | 11:42 AM
Woodlands's Avatar
My dealer test drive to determine if I wanted a 6 speed or auto made it easy for me to go with the auto. The 6 speed was a bear. It just doesn't shift smoothly or have a positive feel.
It is amazing to me that a European car company would build cars with such a weak transmission/shifter. This is especially surprising as most European cars have a manual transmission. However, the auto transmission is entirely different. It has a "performance" feel compared to the typical American auto.
Old Sep 28, 2005 | 12:16 PM
gibsonjunkie's Avatar
Compared to my '99 Mustang GT - this car shifts a lot better.
... and I had a Motorsports clutch in it...
tcar32909
Aug 1, 2024 02:41 PM
jimf
Oct 10, 2015 10:22 AM
nataliefs
Oct 5, 2015 01:03 PM
Abaton6
Sep 24, 2015 10:14 PM
Den656
Sep 23, 2015 12:27 PM
