anyone know the size of these fittings?
Old Dec 1, 2013 | 11:37 AM
JesseJamessrt6's Avatar
Default anyone know the size of these fittings?
I would like to find out the fitting size to the fuel rail and the fuel line that feeds the fuel rail. Crossfire service manual page 14-33. Crossfire parts manual, figure 14-310, item #10, Fuel Hose, part# 05099000AA
A search shows this thread https://www.crossfireforum.org/forum...tml#post411418
Last edited by JesseJamessrt6; Dec 1, 2013 at 11:40 AM. Reason: added pic and link
Old Dec 1, 2013 | 11:50 AM
tunaglove's Avatar
Default Re: anyone know the size of these fittings?
Boostmonkey has a thread with this info.
Old Dec 1, 2013 | 12:27 PM
Thanks!
https://www.crossfireforum.org/forum...t-fitting.html
I even posted in this thread......
I am trying to get a mechanical gauge and a zeitronix fuel pressure sensor all at this location. I am trying to find what the part #'s are for the fittings you ended up finding that worked? Komatsu - 4 fittings with M14 threads and a 30 degree double ended cone to adapt the male thread/female flare on the fuel rail to male thread/male flare? I would also need a miniature block/rail with 2 1/8" npt openings.
Old Dec 1, 2013 | 01:46 PM
tunaglove's Avatar
I ended up going to Pirtek so I never got numbers.
Old Dec 1, 2013 | 02:13 PM
NeedsWings's Avatar
if you are referring to the port on the end of the rail that is JIC. we have the adaptors and also a 2-1 brass block to mount both a mechanical and electric FP sensor there.
Old Dec 1, 2013 | 02:14 PM
It may be time to admit "uncle" and bother Rob for a set up that will work right from the beginning.
Old Dec 1, 2013 | 02:15 PM
Ha ha ha, look at that!!!!
Rob I have e-mailed you.
Thanks again!
Old Dec 1, 2013 | 02:20 PM
I am actually wanting to get pressure readings just before the rail, not at the end.
Old Dec 1, 2013 | 03:34 PM
dinasrt's Avatar
Subscribed.
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
waldig
Aug 5, 2015 02:29 PM
crymar
Jul 17, 2015 08:46 AM
2004_
Jul 13, 2015 02:04 PM
syfi
Jul 12, 2015 05:59 PM
