74mm throttle body on ebay
Old Dec 11, 2013 | 08:28 AM
Default 74mm throttle body on ebay
Not me, but ran across this at $56 w/free shipping if anyone is interested :
http://www.ebay.com/itm/DAP-W220-MERCEDES-03-S430-THROTTLE-BODY-ASSEMBLY-INTAKE-18-/141019391923?pt=Motors_Car_Truck_Parts_Accessories
( the picture shows the correct part number for the NA upgrade : 113 141 0125 )
Old Dec 11, 2013 | 09:58 AM
Default Re: 74mm throttle body on ebay
Great deal at that price.
Old Dec 11, 2013 | 10:57 AM
Remember to get/replace the o-ring between the TB and manifold!
Old Jan 10, 2014 | 12:21 PM
mobilefitt's Avatar
Question!
I am new to modding the Xfire but I'm moving right along. Tune, exhaust, lowered, Leds. I am looking to do sprint booster and intake/TB.
Can we do the TB Swap and keep stock filter/engine cover? or do we need to update that or do Needs wings to accommodate the TB?
Old Jan 10, 2014 | 12:48 PM
Mrmiata's Avatar
Originally Posted by mobilefitt
Question!
Kept mine for a while.. then graduated to "hot air intake".. free flowing over stock system.
Red 2004 2008 Chrysler Crossfire 3 2 3 2L Dual Twin Air Intake Kit Systems | eBay
Old Jan 28, 2014 | 09:52 AM
mobilefitt's Avatar
Default
Where do I get this o-ring? Can I use Lehigh temp perm ex black?
Old Jan 28, 2014 | 09:57 AM
NO permatex :
O RING. Supercharger & Related Parts; Throttle Body; Throttle Body and Related. Fits: CHRYSLER (2004-2008), DODGE (2011), JEEP (2010), . # 05102933AA
Old Jan 28, 2014 | 10:32 AM
Definitely use the O-ring.
Old Jan 28, 2014 | 12:08 PM
mobilefitt's Avatar
thanks for spoon feeding me the info.... here is a Mercedes conversion part #
A 305 997 03 45
Bought it for $15 at the dealership. Chrysler was out of them.
Now, can anyone tell me how to determine if a TB is functional before I try to install it?
I the throttle blade seems to return to the closed position quite slowly. I was expecting it to snap back in place when forced open. Is that normal??
Old Jan 28, 2014 | 12:22 PM
A 305 997 03 45
Forced? You do not want to be forcing this puppy, you are driving a gear and motor in the wrong direction mechanically. You will ruin it in no time flat.
It should be like that, it is not a regular carburetor set up.
Old Jan 28, 2014 | 12:26 PM
mobilefitt's Avatar
Yes, I know this. I haven't been sitting here snapping it back and forth since I typed the last response. Just opened the blade 2 x to see how quickly it returned to the closed position and to see if it in fact returned to the closed position, but thanks for your concern.
Old Jan 28, 2014 | 12:57 PM
MJPowers's Avatar
To test the TB, you can unplug the wire harness from the mounted TB and plug it into the uninstalled TB. Turn the car on and depress the gas pedal, and you should be able to see the plate open and close. I did this and have a video of it. Not sure you really need to do the test since it won't take that much time to install it and start the car.
Old Jan 28, 2014 | 03:17 PM
mobilefitt's Avatar
Exactly what I planned to do! Thanks!
Anyone have a link to a DIY for the install? Ill prob have a tech do it, but sometimes it's good to give him instructions when he works on non - Audi cars
Old Jan 28, 2014 | 03:38 PM
https://www.crossfireforum.org/forum...ade-guide.html
Old Jan 28, 2014 | 04:38 PM
mobilefitt's Avatar
Ok, just to clarify... I purchased a TB and MAF combo- used. Will the larger MAF fit the stock Engine Cover?
Or do I need to use the Stock MAF until I get an Intake?
Old Jan 28, 2014 | 06:33 PM
The MAF is the same size externally and will fit. But you must switch the sensors, the original MAF sensor on the Crossfire goes onto the new MAF unit.
See here for details.
Old Jan 29, 2014 | 12:18 PM
mobilefitt's Avatar
I couldn't get the star bolts out of my sensor, so I bolted the new TB to the manifold with an new o-ring and some rvt. I used the old Mass Air Flow Assembly until I can find a way to get these bolts out. Does anyone know the thread pitch of the bolts.
Old Jan 29, 2014 | 12:31 PM
They have a fast thread on them, I unscrewed mine using a regular flat bladed screwdriver that just went into the slots. I think they are an odd ball tamper proof five sided Torx screw. I messed up the screw head a bit but they came out.
Old Jan 29, 2014 | 01:04 PM
mobilefitt's Avatar
I tried with the flat head. NO GO. I didn't want to destroy the bolts. I am looking to replace them with manageable bolts if possible. In the mean time, I am going to the store to get the tool designed to remove them. I don't have the assembly with me, but I want to get the tool and the replacement bolts.
HOW about the name of the style head that is so I can shop for a Tool? saftey 5 star anti-tamper a-25 or something like that....
Old Jan 29, 2014 | 02:37 PM
The flat head is small and goes in beside the pin and jams in the corners. I did it and Beaner did it, it works fine when you get the correct size screwdriver. He told me what to do.
