Crossfire Heater Blower On / Off / On / Off
Old Jan 7, 2014 | 06:37 AM
2andym's Avatar
Default Crossfire Heater Blower On / Off / On / Off
Hi Folks,
Im looking for some information on the heater on my 2005 05 plate crossfire, the heater
blower has started to be intermitent on off on off etc etc.
I have read through some of the posts on this forum and I'm now thinking its the blower
resistor, I live in Ayrshire Scotland can anyone tell me the best place to purchase the blower
resistorand roughly what i should pay realisticly.
Cheers Folks any info will be much appreciated.
Old Jan 7, 2014 | 09:20 AM
Default Re: Crossfire Heater Blower On / Off / On / Off
try this
https://www.crossfireforum.org/forum...ht=blower+work
or this
the part is under the glove box 2 of 3 screws and it is out you may have to use the factory wire, as the one that comes with the part is too short good luck jim
Old Jan 7, 2014 | 09:26 AM
2andym's Avatar
Default
Originally Posted by amx1397
try this
or this
Hi thanks for info much appreciated will post outcome cheers again Andy
Old Jun 16, 2014 | 08:37 AM
davmar0220's Avatar
Hi,
You have a faulty resistor, very common fault, Ive just purchased a new Resistor from ebay, item number 110930398302, It's from a Mrecedes SLK 200, exact same as Crossfire, £20, 10 minute job to swap over, hope this helps.
Old Jun 16, 2014 | 09:44 AM
Thornh's Avatar
I agree that the resistor is the place to start with this issue, as it is the least expensive to replace. However the resistor did not fix my intermittent blower issue, it wound up being the control unit (the one in the center stack with the adjustment *****). There are several threads relating to these heater/AC issues here on the forum, and if memory serves there is one that gives instructions to test/troubleshoot before you start throwing money at it. Good Luck!
Old Jun 16, 2014 | 10:08 PM
More current threads discussing the problems and install video for the blower motor resistor too
How to test your A/C Heater Blower Motor and Resistor
Blower motor resistor
HVAC Fan Regulator Replacement
The blower motor resistor can be purchased at a very low cost here:
A C Fan Blower Motor Resistor RU567 Fits Mercedes SLK320 SLK350 AMG 2108206210 | eBay
Frankenmerc
20
Dec 13, 2025 11:51 PM
BEATv1
Jul 16, 2015 09:40 AM
BEATv1
Jun 12, 2015 05:20 PM
racingagent
Jun 8, 2015 07:29 PM
MJPowers
Jun 8, 2015 02:34 AM
