Heater/air fan
Old Dec 20, 2013 | 07:59 PM
cg80's Avatar
Default Heater/air fan
Heater/fan blower working 1 minute...not working the next...any thoughts from owners who have had this problem?
Old Dec 20, 2013 | 08:10 PM
Default Re: Heater/air fan
Most problems occur with the regulator which is mounted on the back of the fan, see picture, these are quite expensive. MMZ-Timelord was working on a cheaper and more reliable part to replace this item.
Old Dec 20, 2013 | 08:21 PM
cg80's Avatar
180: Thanks for the rapid response... how expensive is "quite expensive" and approximate degree of removal/installation for a # 7 mechanically savvy guy? Appreciate the help...Carl
Old Dec 20, 2013 | 08:35 PM
Mrmiata's Avatar
Don't know the price range on these things.. but here's this..
http://www.ebay.com/itm/OEM-A-C-Blower-Regulator-Mercedes-MB-W104-W111-W112-113-/370458817556?pt=Motors_Car_Truck_Parts_Accessories&hash=item564110f414&vxp=mtr
Old Dec 20, 2013 | 08:44 PM
Here is an expensive one, that's because it is listed as a part for the Crossfire. Get one which is the same part but with an Mercedes number. They are simple to change, take out the heater blower and install this in place of the broken one.
Another common failure is the fan speed control on the dash, it is a toss up which has failed
http://www.ebay.com/itm/Chrysler-Crossfire-Blower-Motor-Resistor-OEM-Mopar-5096900AD-HVAC-Resistor-04-08-/111041212248?pt=Motors_Car_Truck_Parts_Accessories&hash=item19da926f58&vxp=mtr
Old Dec 20, 2013 | 08:45 PM
cg80's Avatar
A C Blower Regulator Mercedes MB W104 W111 W112 113 | eBay
Greg: Thanks for the info...cost is 145.00!! Carl
Old Dec 20, 2013 | 08:58 PM
cg80's Avatar
Expensive
180: Thanks for the info...your're right, the Mercedes onecost 145.00 and the Crossfire one 293.00...You've been a lot of help...Carl
Old Dec 20, 2013 | 09:00 PM
Cheaper part.
eBay new and used. From $48.00.
The part you need is Mercedes part #210 870 02 10
Old Dec 20, 2013 | 09:05 PM
Mrmiata's Avatar
They look the same.. but please contact seller as noted in the auction..
Just noted 180's post.. use mine if his link is on backorder indefinitely ..
Old Dec 20, 2013 | 09:15 PM
cg80's Avatar
Cheaper part.
180: you and Mrmiata are a life saver...I owe you 1 ,2, 3,4 and so on...Thanks heaps.Carl
Old Dec 23, 2013 | 01:20 AM
Paul Bosslet's Avatar
Hi,
I bought mine from RockAuto under Mercedes 2004 SLK320 section...about $60.00. Works great except I had to reuse the foam gasket from the original part.
Old Dec 23, 2013 | 12:15 PM
cg80's Avatar
Originally Posted by Paul Bosslet
Hi,
Thanks, Paul for the info...Carl
Valk
Jul 12, 2021 09:49 PM
Nov 11, 2015 05:22 AM
Oct 1, 2015 01:42 AM
RiderJC
Sep 7, 2015 11:19 PM
williammt
Sep 6, 2015 11:23 AM
