Top will not go down/up
Old Jan 23, 2014 | 03:26 PM
cuziamninja's Avatar
Default Top will not go down/up
Edit
Problem Solved!
Old Jan 23, 2014 | 03:52 PM
Default Re: Top will not go down/up
I doubt the two problems are related. You are describing a bad pump or low fluid in the hydraulic system. Check the resivour, it should be 1/3 or more full even when the system is pressurized. MANUALLY open the deck lid and look at the level in the tank on the driver's side in the wheel well. I bet there is little in there -and look around for leaks!
https://www.crossfireforum.org/forum...operation.html
Spoiler problems are usually an indication of a bad battery or wheel speed sensor.
Old Jan 23, 2014 | 05:49 PM
Thank you so much for the detailed reply Pizzaguy, I really think that this might be the problem. I have seen the video for the manual top operation, and I was wondering if there was any way to open the section of the trunk the top goes into without the $150 tool? And I've searched around the forum for a bit but I haven't located a tutorial on which type of hydraulic fluid I should use, and I how I should go about filling it up! Thanks.
Old Jan 23, 2014 | 07:22 PM
Mrmiata's Avatar
$150 ? dang I need to burn some more and charge more than that 6 bucks shipping!
I've got my "personal" one that I burned (sent my oem off in an emergency case)..If you need it send me a PM..
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
