Service indicator on ODO screen?
Old Apr 7, 2014 | 01:04 PM
32seventeen's Avatar
Default Service indicator on ODO screen?
I have only had this x-fire for 4k and now when you first start it, the ODO screen shows a wrench, a dash and then the number 200. I am guessing this mean that the car thinks it needs service in 200 miles?
How do I know what serive it requires and how do I reset the service indicator? I already searched the site and came up empty.
BTW, the car currently has 32k on it.
Thx
Old Apr 7, 2014 | 08:00 PM
robby363's Avatar
Default Re: Service indicator on ODO screen?
Thx
It's time for a oil change in 200 miles.
Old Apr 8, 2014 | 11:09 AM
I guess this is just a re-occuring reminder based on a pre-selected mileage interval, not actual mileage since the last oil change?
Chrysler changed the oil slightly less than 4k ago.
Do I need to reset it, like on my Ram truck?
Old Apr 18, 2014 | 11:34 AM
So, the number keeps going up. Which must mean that it thinks I am past due on the oil change.
How do I reset this thing?
Old Apr 18, 2014 | 11:48 AM
It can be assumed that the FSS indicator was not set when the oil was changed.
Use 'FSS' in the search feature and the instructions to reset it should come up.
Or click here.
Old Apr 18, 2014 | 12:15 PM
Or click here.
It was changed by the Dodge dealer before I bought it. It has about 4k on the oil now.
Thanks for the link. The vid at the end of the thread is great. I will reset it before I drive home today, but then it won't remind me at the correct time. Oh well.
Old Apr 18, 2014 | 12:39 PM
Maybe you should change the oil with Mobil 1 10W40 and start all over. If it says change the oil then you should, something is whacky, maybe they never used the correct oil in the first place.
I would never go to the limit anyway, but that's just me.
Old Apr 18, 2014 | 01:06 PM
The car was reconditioned at the dealer. They changed the oil as part of their service. I saw the ticket on the work, and it showed 9 quarts of mobil 1.
My guess is that it got changed early at the dealer and they where probably not familiar with the MB fss reset, and now that car thinks that it is past 7k on the oil change. No biggie.
I know when it will be due for the next change, so I will just keep track of the milage myself and reset it on the next change to get everything on the same page.
Old Apr 18, 2014 | 01:22 PM
Changed early?
Old Apr 18, 2014 | 01:41 PM
Changed early?
Yeah, early. If they changed it at 3k (early) and did not reset the FSS, then sold it, and I drove it another 4k. That would explain why it is coming on now. 7k from the last reset, even though it really only has 4k on the oil.
Old Apr 18, 2014 | 02:03 PM
RL67037's Avatar
Just a note on the FSS - from what I've read here and what I've seen on my car, the FSS does not simply count off 7K miles. It monitors several sensors on the car and adjusts the mileage between changes accordingly. I think if you hit the button within one second of turning the key to the "On" (not Start) position, you will see the remaining miles the FSS is showing. Depending on how you drive your car, if you check it again in, say, 100 miles, it probably won't have changed 100 miles - it might be more or it might be less. That said, I'm with 180 on this - I wouldn't run my car to the limit of the FSS - change the oil a bit early and all should be well.
Old Apr 18, 2014 | 02:09 PM
So you are saying what I said in post #5 and appeared not to agree with at that time.
Good luck.
Old Apr 18, 2014 | 02:33 PM
Good luck.
I did not disagree with post #5. I think your assumption is correct and I also seriously doubt it was reset by the dealer.
None of the dodge sales guys even knew it had a MB engine in it.
I thought these cars were in the 7 to 10k range for oil changes. I'm not sure why I would want to change it now? I have never changed a high end full synthetic at such a short interval.
eikon
Sep 9, 2019 10:16 PM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Abaton6
Sep 24, 2015 10:14 PM
smokey847
Sep 15, 2015 10:47 AM
