dead battery
Old Apr 21, 2014 | 04:46 PM
moparmanpr's Avatar
Unhappy dead battery
have an '05 crossfire roadster. when the car is parked for a week un-driven, the battery is dead. with an ammeter i found there is a .778 amp draw even with the ign. off. pulled each fuse & tested after each one & the drain is always there. any ideas? i'm stumped.
Old Apr 24, 2014 | 08:25 AM
DTMenace's Avatar
Default Re: dead battery
moparmanpr
A little more detail is needed to diagnose your battery issue, let's set aside your testing at this time. Do you have the original battery (White/opaque case) which is a Varta? When was the battery changed, if it's not a Varta? Anytime the Crossfires sit idle for a period of time, it's good to buy a battery tender and hook it up to maintain the battery strength, costs about $30.
One issue with any car with advanced electronics, is they are sensitive to any variance in lower voltage. The security system could be a culprit, in using the voltage?
Dennis
DTMenace
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
