unresponsive gas pedal srt-6 please help
Old Jun 5, 2014 | 10:54 AM
kookus's Avatar
Exclamation unresponsive gas pedal srt-6 please help
Hi everyone,
Firts time poster and new to the forums. Just bought my crossfire 4 days ago. After an awsome drive home from Dallas to guldport, ms. stopping several times for gas, restrooms, food and driver swaping with zero issues. I wake up next morning to drive my new baby to work.
.....and then i have this problem now. car starts and runs but pushing gas pedal does nothing except very slight hesitant forward motion like idle speed. there are no lights on dash on. i can change gears with the auto stick. but when i step on the gas car acts like it doesnt know that i am. have done last few days of searching the forums and belive it to be one of these 3 things... but not sure witch.
throttle position sensor
or cam shaft position sensor
or the connector box.
btw i do have a obd reader i will look at when i get back home and update what it says.
the car is automatic SRT-6 Roadster with about 95k miles.
any and all help will be apreciated.
thanks Brian
Old Jun 5, 2014 | 11:02 AM
grip grip's Avatar
Default Re: unresponsive gas pedal srt-6 please help
Damn, sorry to hear of trouble so soon. If it's the spiders gears, I have a couple. You can have one if you cover shipping.
Old Jun 5, 2014 | 12:38 PM
kookus's Avatar
thanks grip, but im not sure where or what spider gears are or how they would play a part in this. havent found any reference to them yet.
a bit of an update....
the code shown is throttle / pedal position sensor. P0120. so i guess i start with one of those.
also some more info...
i can drive the car around the block but only with idle rpms.
the previous owner replied to a question i texted him and says it has happened to him once or twice... and went away.....and failed to tell me when i bought the car.
any suggestions on what to replace first ??
thanks
Old Jun 5, 2014 | 12:42 PM
Originally Posted by kookus
Hi everyone,
thanks Brian
If the engine does not rev then I'd guess the TPS or the accelerator pedal assembly.
Old Jun 5, 2014 | 07:00 PM
kookus's Avatar
update....
i decided to try out the throttle reset....woot it fixed it.
if it happens again ill see about replacing or trying to fix what ever is the culprit.
did find out i need a serpentine belt as well though. no one had it in stock so i had to order it. how much work is involved in replacing it. do you have to take a bunch of parts off to?
Old Jun 5, 2014 | 09:53 PM
Did find out i need a serpentine belt as well though.
Nothing to take off other than the old belt
View the beginning of the thread linked below
serpentine belt replacement
Old Jun 6, 2014 | 06:01 PM
kookus's Avatar
fyi for SRT-6 there is a pulley for the supercharger that you must remove, but, its simple.
and another update no power messing up again after 2 days of good driving.....wierd.
UNDER PSI
Nov 1, 2015 09:39 PM
miscetera
Oct 5, 2015 11:40 AM
BlackJax-SRT
Sep 18, 2015 07:03 PM
RacerXofFL
Sep 15, 2015 05:00 PM
MickeyNasty
Sep 6, 2015 08:29 PM
