New guy
![Default](https://www.crossfireforum.org/forum/images/icons/icon1.gif)
Hello Guys,
Just thought I'd pop my head in and say I am the new guy. Just about to buy a crossfire from my local garage for my missus. Was just wondering if anybody had any tips for things to look for when buying. She lives these cars and has recently got a new job closer to home so we are treating her with a little sports car toy. I have a Chrysler 300c so we are big Chrysler fans.
Anyone got any tips for what to examine before purchase? Any common faults I can look for?
I have already seen there is a bit if a common fault with a seal in the engine. Can't remember what it's called. It looks as this one I have seen has it as there is a small amount if engine oil leak. I have been told he will fix it prior to test drive and I will pay the AA to come and inspect. Anything else?
Thanks
Pete
Thanks
Pete
First of all, welcome to the forum.
Without knowing much about the car you are looking for, it's hard to advise you. You should look at the headliner, making sure it's tidy, but it isn't a deal breaker if it's not, but it may help in your negotiations. If you have a mechanic friend or a good shop nearby, you could have them check it out for you, compression, etc otherwise, you can do the common stuff. Look at all the bolts on the motor, see if they have been removed or not, it may tell you if the motor has been worked on. You can put a dollar bill at the exhaust and see if it flutters or sucks back in. You want a flutter, if it sucks it back up against the tailpipe it could indicate that you have a bad valve sucking air. Look at the tires and see how they're wearing, any alignment problems will show up in their wear. Look around all the trim to see if any overspray is on it or the rubber, it may indicate that it's been repainted or repaired. If you could have them put it up on the rack, a good visual look on the underside can tell you a lot. Check the brakes for pulling or noise. See if the car is pulling during your test drive(s). And of course a good detail inspection of everything, listening to the motor; after you make sure the radio works - turn it off, if you hear anything strange, put it in neutral and see if it goes away, that could tell you if it's in the engine/trans or the drive train. And, ask questions, every question you can think of and don't accept answers that make no sense.
Good luck,
Dave
Good luck,
Dave
on
1 Post
One place to check for rust on these cars are the bottom of the doors. You have to pull the rubber seal off to check for rust on the metal flange that holds the rubber on. One thing I insist on when buying a used vehicle is that put the car on the lift and let me inspect underneath for damage, leaks, rust or anything else that might look out of place. I have only had two places refuse siting insurance liability and, I walked away from both. Another thing I do before taking delivery is to go over every system right down to the light bulbs, turn signals, brake lights, back up lights, wipers, radio/cd player, door locks, convertible top operation, door latches, headliner, power seat operation rear window defroster, you get the point. I also insist on fresh oil. I know there are others that escape me right now
Thanks for all your help and advice guys.
This one I'm looking at has a slight leak in the 'rocker covers' according to the garage owner. He has offered to fix them. Is this a major job? Is it fixable and will it ever go again? There was a slight leak of oil on the engine that was coming from the top. Is this the right place for rocker cover. Would anyone advise not to touch it?
Here's the DIY : https://www.crossfireforum.org/forum...over-leak.html
Once sealed correctly, usually good for several years.
We are the proud owners of a 2006 (56 plate) Crossfire. 59,000 on the clock. Mint condition. Absolutely made up. Got it at a steal because the garage couldn't sell it for a year. Rocker seals replaced, service, MOT and a dam good clean.
The only down fall in the car is that it doesn't have HID lights? It's only got projectors filliment bulbs. Has anyone do e a conversion or can you buy the clusters with HID already set up?
You will want a H7 kit, there are many low cost ones available, and a few modest and high cost ones.
Most agree that the Morimoto kit is the best bang for the buck ( from The Retrofit Source Inc ).
It is a hassle, but the kits are MUCH easier to install if you remove the units, with the added benefit of being able to mount the ballasts under the units.
( You can also install a 9006 kit in the fog lights )
on
H7: Morimoto Elite HID System - HID Systems from The Retrofit Source Inc
Edit: Alax beat me to it!
You might want to inquire on the U.K. sub-forum under the Regional forums. Guys like Doc may be able to answer that correctly.
( I don't know about "self leveling", but you should be able to adjust them from the cockpit )
Enjoy,
Right,
Pick up the car later today hopefully.
One thing in have realised is that there is no cup holder. I have seen the problems that people have had with the OEM cup holder so what have people done instead of the OEM holder? Any links to the solution?
Anyone have any good site suggestions for mods? I have a 300c so I'm well adversed on mods and know a few good sites for the 300 but can't find many for the Crossfire. Preferably UK sites and at a push US or other sites that ship to the UK.
on
https://www.crossfireforum.org/forum...up-holder.html
o55ie18
10-05-2015 05:50 PM
thatcham
10-05-2015 02:41 PM
