"New" Car, New Member
I just picked up my white 2005 Limited roadster Saturday evening: 6 speed, 73k miles. I've got a few things to sort out before I can get it on the road. The back tires were bald, so I have a new pair on the way from the Tire Rack: Hankook Ventus S1 Noble's.
The mirror switch was broken, but I scored a replacement in the junkyard for $20 today. Now I gotta figure out how to get the console apart to get it in.
The yard threw in an extra key fob, too. My key remote buttons don't work. New batteries didn't bring it to life. I tried to reprogram it too using the method in the manual. Still didn't work. I found an online procedure that says you put the key in the ignition first. That didn't work either. Tried it with the junkyard key, too by putting the original key in the ignition, but punching the buttons on the junkyard remote. That didn't work either. So I wonder whether I have two bad remotes, or could there be a problem with the receiver in the car?
I also need a front license plate bracket, too, since the car came from NC via SC & FL. Apparently you have to drill the front bumper to install a front bracket? So says my local Chrysler parts dealer, although he really wasn't sure.
Lastly, the right rear taillight is broken, so I'm on the prowl for a replacement. It might not pass inspection that way, so I'm thinking I need it right away to get the car on the road.
Anyways, I'm tickled to have the car, and looking forward to getting it on the road in time for viewing fall colors in a beautiful blur.
Thomas
Thomas
Grats on your purchase.
The fob from the scrap yard will not work unless it is programmed by mercedes.
I seen somewhere a video on repairing your original fob. Check youtube.
To get console apart you have to take the radio out first, need mercedes radio keys.
Tires on our car are important, I run rain tires, Falken's on front and G-Max's on rear and like this combo. I have burned through summito's and Goodyear f1's
Since you are in nc/SC area you should join the crossfire group for the dragon run in fontana.
Re: "New" Car, New Member
I've been reading carefully about remotes. I understand that I need the transponder to make the car start. But how close does it have to be to the ignition switch? Does it have to be IN the switch? Or can it just be in the car, like my friend's 2013 Jeep? If the latter, then shouldn't I be able to get the junkyard fob to "re-program" to open the doors if I have both fobs in the car, with the original fob in the ignition switch?
Bet nobody's ever tried this...?
Others may chime in, but from everything I've read before used Crossfire key fobs cannot be reprogrammed for another Crossfire. The coded security chip in the fob will only work with the car it was set up for.
Thanks for the attempt, Toolman & Speedy4x4, but you haven't really addressed the question I've posed, have you? I'm asking HOW CLOSE the fob has to be to the ignition switch to work. I realize that you need a fob programmed to work with that car to turn the car on. And undoubtedly I do have such a fob, because I can start and drive my car.
What I'm really driving at is whether I should attempt to take both fobs apart and transplant everything from the junkyard fob EXCEPT the transponder. Or would that be a waste of time? It would definitely be a waste of time if I knew the junkyard fob was dead. But does the transponder talk to the circuit board in such a way that the transponder won't work if the circuit board isn't programmed to match?
And one of the questions I'm trying to nail down is why my original remote won't unlock the doors. I installed new batteries. I used the factory service manual procedure to "reprogram" it. And still the buttons don't work. I'd like to confirm that it's actually the remote that's the problem, and not something else wrong with the car (like a bad receiver? can that happen?) before I spend money on a new fob. Or two.
Thomas
Thomas
Thomas
https://www.crossfireforum.org/forum...unctional.html
Possibility exists that water has gotten into your trunk somehow & ruined this module.
Later,
rayth
41
07-31-2019 04:02 PM
mhajek18
12-30-2015 03:40 PM
itsky
-C-I-C-C-I Discussion
07-11-2015 11:23 PM
ultrajim49
17
06-27-2015 12:20 AM
