SRT sub replacement help!!!
Old Oct 17, 2014 | 10:18 PM
Shanep's Avatar
Default SRT sub replacement help!!!
Does anyone know if I can replace the 2 rear subs with 2 regular speakers that have bass & still be able to use the existing wires & factory amp?
Old Oct 18, 2014 | 01:26 AM
Thornh's Avatar
Default Re: SRT sub replacement help!!!
I don't believe that will work the subs in the rear are dual voice coil and any speaker placed there will only produce bass. I wound up replacing them with Earthquake SWS 6.5's they are a shallow mount sub that will fit in the stock brackets wit a little modification. The drawback to that is you will also have to bypass the factory amp and use an aftermarket amp to get enough power to drive them properly. If you search here on the forum you will find multiple threads regarding the rear subs and if I remember correctly there is a reference somewhere to a supplier for replacement surrounds for the factory subs which may be all you need to get them functioning properly again.
Old Oct 18, 2014 | 07:44 AM
Shanep's Avatar
Thank u for your response.
Kodebuster
Nov 5, 2020 04:06 PM
4drturbo
Jan 3, 2019 02:46 PM
Roty135
17
Oct 11, 2018 10:11 AM
RED DOG
Jul 21, 2015 07:58 AM
Fildo Dog
Jul 6, 2015 05:20 PM
