new subs hookup
Old Apr 19, 2015 | 09:56 AM
gig's Avatar
gig
Default new subs hookup
ok trying to hookup an all in one subs and amp in the back of my xfire the rear stock subs suck so want a little more bass also hooking up new stereo, stereo is hooked up and running no issues with the stock amp, ok thought i would ran an another all in one small amp and sub, ran the wire to battery and ground and remote wire no problem amp powers up green light ran rca cables to new stereo ok problems begin where do i plug in the cables to the stereo there is one plug that says woofer out but only one where does the other rca cable go. ive tried plugging cables into the jacks for the two front speakers, amp is running but no volume can hear it alittle bit, do i have to run the amp to the factory amp? i even tried hooking up to the rear subs no luck, i just want to have a seperate sytem but cant seem to figure it out , need help lol
Old Apr 19, 2015 | 10:14 AM
Mrmiata's Avatar
Default Re: new subs hookup
I'm guessing the place to start with this might be what components are you trying to use (model specific). My aftermarket stereo had two channel sub out.. and the amplified bass cannon in back of my car works fine - speaker lead output to stock amp and RCA to cannon.
Old Apr 19, 2015 | 11:32 AM
gig's Avatar
gig
ok its 2 channel from china pumpkin is the name lol no issue with stereo love it like i said amp works can hear a bit of bass but makes no different when i turn up volume amp has its own volume control, stereo has tons of rca cables coming out of it for front speaker rear speakers all red and white and one that says woofer out so are you saying that i put one of the rca cables in the woofer out and the other one to the factory amp, factory amp has no rca outputs thats what i need to know can i run the all in one seperate from the factory amp or do i have to bridge it and if i do how do i do that lol just want some bass in the back the factory woofers really suck
Old Apr 19, 2015 | 12:32 PM
Mrmiata's Avatar
Run it separate from the factory amp.. as I had noted I'm RCA out from my HU to the amplified bass cannon.
Old Apr 19, 2015 | 09:42 PM
gig's Avatar
gig
ok i scrapped the all in one amp and sub couldnt get it to work, now i just have a dual 12 inch mtx subs no amp, do i wire it to my factory amp and if i do how do i do that all help welcome im having no luck with this lol
usprb1976
Apr 4, 2024 04:57 PM
blackpepper
Dec 18, 2021 06:17 PM
Jocko124
Sep 29, 2015 11:39 AM
RacerXofFL
Sep 15, 2015 05:00 PM
Jocko124
Sep 5, 2015 09:10 PM
