Gurgle
Old Sep 14, 2015 | 03:45 PM
cppeabody's Avatar
Default Gurgle
Dear People!
I've a manual n/a '05 crossfire with 56,000 miles on it. This morning, I noticed a gurgling noise coming from what sounded like inside the dash, so it's probably in the engine bay. There was also a periodic knock every few seconds.
I've yet to check the water pump pulley, and was wondering if there were a few other things I could look at before going ahead and getting a new pump (i.e. how to check for air in the system/bleed it,)
Thank you for your help!
Old Sep 14, 2015 | 08:25 PM
ATX SRT-6's Avatar
Default Re: Gurgle
If you hear gurgling in your dash it could be the drain for your evaporator that's clogged up.
You can find it by reaching way back into the tranny tunnel while standing on the drivers side with the hood up. You can also see it in the car if you take the floor AC vent off on the drivers side. That will give you an idea were to feel for it in the tunnel
Under the dash cowling there are two more drains for the cowling itself. Those might be clogged to and holding water.
Old Sep 15, 2015 | 08:43 AM
cppeabody's Avatar
Default Re: Gurgle
Thank you! It only seems to happen when I have the AC turned on. I didn't run the AC this morning and sound wasn't present. I'll check that out and let you know...
rayth
May 7, 2015 02:21 PM
TomStratRT
23
Jun 8, 2012 03:36 PM
srt666
15
Mar 24, 2011 05:01 PM
Deborah Walker
Jun 29, 2009 11:19 AM
Coyote
Jan 17, 2009 08:54 PM
