Air injection pump won't turn off
Old Sep 20, 2015 | 05:59 PM
Wisconsinfdcrossfire's Avatar
Default Air injection pump won't turn off
I've got a 2004 crossfire. When I turn the key off the air injection pump continues to run. I had to unplug the wiring to it top get it top turn off. When plugged back in it stays running again. Is there a fix for this? I couldn't find any other threads about this problem. I was working on the stereo system and arched a couple wires, but the problem didn't start until the second time after that I started it. I don't think this would have anything to do with it anyway. Any ideas out there?
Old Sep 20, 2015 | 06:17 PM
Default Re: Air injection pump won't turn off
The air pump relay ( #5 ) contacts are fused together in the RCM ( Relay Control Module ).
It is the module closest to the engine in the box by the battery.
Remove the RCM and send it to DJ ( tighed1 ) for repair.
( See thread "Mystery No Start" )
Old Sep 20, 2015 | 08:45 PM
Thank you for the picture. I was able to clean up the points on my own. I would recommend laying a towel or something down if you're going to take the small spring off, mine fell into the engine compartment and I got super lucky that it went down to the floor. Thanks again saved me a lot of time diagnosing.
Old Sep 20, 2015 | 10:04 PM
Replace the relay as filing it is just a temporary fix. The relay costs a lot less than a replacement pump.
BrenLW
Aug 5, 2015 04:53 AM
waldig
Jul 30, 2015 07:39 PM
crymar
Jul 17, 2015 08:46 AM
cx24724
Jul 12, 2015 11:57 AM
ja.nko
Jul 10, 2015 03:21 PM
