Be Wary Of Online Companies
Old Feb 10, 2005 | 12:49 AM
HDDP's Avatar
Default Be Wary Of Online Companies
Dear forum members:
I'm starting to notice a trend with "Crossfire" aftermarket parts vendors that seems to be less than professional IMO.
As many of us know, certain Crossfire shops who started a few years ago had some problems delivering the products they advertised on the internet. Now, that trend is continuing with technical, suspension, braking and engine modifications.
Please be very wary of any company that has now started to advertise specific modifications for the Crossfire. In my research, I have found that many will immediately respond that they have modded the SLK320 and many other MB models. But, when asked to provide specs on the SLK320 vs. Crossfire, they are at a loss.
I can safely say, stay away from BERGWERKS as they have shut down their facility and even though they have a large internet presence, they no longer have a facility to perform the work and have led me on a two month process of changing my differential from 3.27:1 to 3.69:1.
I have also had numerous conversations with other vendors who purport to have extensive experience in modding MB cars, but cannot provide the specifications of the modifications I requested. Nor can they verify the crossover parts from other MB models or aftermarket parts, even though they have stated they would have the information within 24 hours and return my call.
I'm still waiting for the calls !!! and the crossover specifications !!!
In my humble and often overbearing opinion, be very careful. As we have found out, not even $1,000 forum giveaways are what they appear to be.
This is only my humble opionion. CYA when you're dealing with vendors who purport to have aftermarket modifications or products for the Crossfire!!!
Old Feb 10, 2005 | 05:47 AM
x'ed's Avatar
Default Re: Be Wary Of Online Companies
hey hddp, i have noticed that you have saskins intake. how would you rate performance hp increase, butt dyno style?
Old Feb 10, 2005 | 10:15 AM
mjanowich's Avatar
It seems like everyone is trying to ride the import tuner wave by trying to sell aftermarket junk. I guess that's why companies like Renntech are so expensive, because they have actual engineers working for them and they know what they are doing. Good luck with the gear change.
Old Feb 10, 2005 | 01:26 PM
toplessrental's Avatar
Originally Posted by HDDP
Dear forum members:
Good information here.
I have been trying to connect with StarTech people about this contest but I only have Europe office info. Does anyone know if there is an office here in U.S. If so, appreciate email or phone #.
Old Feb 10, 2005 | 04:34 PM
HDDP's Avatar
I have no numbers to quote, only seat of the pants feel. It pulls much stronger through all the gears and seems to have much more torque. I'm in the process of wrapping the entire thing in a heat shield from CIS because I know when it warms-up here in CA it won't be as effective. It won't be as pretty as the powder coated version, but will definately make a difference.
I won't even guess about HP gain #'s as I never had the car dyno'd before the install.
Old Feb 10, 2005 | 07:23 PM
Dan Root's Avatar
Banned
it should be a easy switch.
Old Feb 10, 2005 | 08:20 PM
HDDP's Avatar
What should be an easy switch? The differential?... OK, since it is so easy, tell me which MB model with a 3.69:1 gear ratio shares the same pumpkin with the SLK320 / Crossfire and also has the same sensor placement connections, and is a 1.3 litre with the same gear sizes???
If you're talking about the sway bars for the SLK320 / Crossfires vs. those of the SLK32 AMG / SRT6. Again, what is the difference that creates the stiffer suspension? Seeing that they are the same external diameter, are they hollow vs. solid, do they have longer/ shorter control arms ?
Lastly, we're talking about switching the rotors and calipers from the SLK32 AMG / SRT6 to the SLK320 / Crossfire. Do you know if the atachment points are the same, clearances etc.?
So, easy switch? Gimme the answers big guy...
Old Feb 10, 2005 | 08:26 PM
Dan Root's Avatar
Banned
air intakes for stock intakes for dyno your last post.
The rear ends have been done before but I'm sorry I don't know who right now. Guys used to change 400Es to Euro spects, it made them feel like 500 Es.
Old Feb 10, 2005 | 08:33 PM
HDDP's Avatar
Oh!!! The air intake switch was a pain in the as* since it was prototype from SASKINS, but now that he has the attachment points, bends and connections dialed-in, I'm sure it is moments away from a PLUG-AND-PLAY system. Nothing that your DIY mechanic can't handle...
As far as dyno, I'm not spending the money... Just like you didn't spend the money to have your car dyno'd before and after your car was chipped by EuroRev.
Old Feb 10, 2005 | 08:37 PM
Dan Root's Avatar
Banned
As for brakes I'm happy with my XD Brembo rotors, and ss brake lines and rotex gold, you'd probably want more performance pads. For AXing.
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
Dementors
Sep 30, 2015 07:46 PM
Billto
Sep 28, 2015 12:05 PM
ozkancab
Sep 25, 2015 10:55 AM
cdcrone123
Sep 14, 2015 09:51 AM
