H7 HID Bulb
Old Oct 31, 2015 | 10:51 AM
Gtsman's Avatar
Default H7 HID Bulb
Just installed Morimoto xb35 4300k hid kit on my roadster. Great quality product and an easy install. One thing I did notice is the shadow in the beam pattern caused by the ground wire being on top. I know this has been discussed before . My plan is to re notch the bulb base to relocate the ground wire on the bottom. Has anyone tried this and did it improve the light quality. Thank you in advance.
Old Oct 31, 2015 | 11:56 AM
syfi's Avatar
Default Re: H7 HID Bulb
Adrian has done this with great success....
Old Oct 31, 2015 | 01:02 PM
Gtsman's Avatar
Thank you! Was going to order a cheap set of bulbs and try it, but now I will work with the morimotos.
Old Oct 31, 2015 | 05:47 PM
Adrian_X's Avatar
The metal needs exact cutting for fitting. Plus be careful to not bend the rest of the base, as it impacts alignment quite a bit. Do one at a time, and do it where you can mark your beam on a wall or garage door or something.
Old Nov 1, 2015 | 07:16 PM
Gtsman's Avatar
Modified and installed bulbs today, very happy with results. Great cut off line and no ground wire shadows. Thanks for the help.
Old Nov 2, 2015 | 01:55 AM
Adrian_X's Avatar
Awesome, welcome to the all seeing club.
Old Nov 3, 2015 | 01:42 AM
MB04XFIRE's Avatar
I have some morimoto HID's which i will be installing this winter.
Is there any detailed explanations as to how to change the position of the ground wire in order to remove the shadow?
Please let me know.
Thanks
Old Nov 3, 2015 | 09:29 PM
Adrian_X's Avatar
You don't touch the return wire at all, unless you want to replace your bulbs for no reason. You cut notches on the reverse side of the bulb base, opposite the notch already in place. Make it the same dimensions, and you're in business. Nothing more to really explain honestly, just don't bend the bulb base, and DO NOT touch the bulb glass with your fingers. They leave grease behind and damage bulb lifespan easily.
Old Nov 6, 2015 | 02:15 PM
MB04XFIRE's Avatar
Perfect thanks..
When I am ready to do the install I will look into it and if I have any other questions I will send you guys another reply
Red Runner
Sep 15, 2025 12:49 PM
aviram
Oct 27, 2015 09:45 AM
glover
Oct 23, 2015 10:42 PM
39lasalle
Oct 22, 2015 07:51 PM
vvv
Oct 14, 2015 05:27 PM
