help me / where is the neutral safety switch in my chrysler crossfire
Old Nov 6, 2015 | 05:26 PM
flax43's Avatar
Default help me / where is the neutral safety switch in my chrysler crossfire
i have a 2005 coupe base model , and i cant find the location for the neutral safety switch...
i thought it would be near or around the transmission..
i have a automatic....
can somebody please send me pictures or schematics.
Old Nov 7, 2015 | 08:35 AM
kingdavid54's Avatar
Default Re: help me / where is the neutral safety switch in my chrysler crossfire
private message ala_xfire he can probably answer your question, be sure to include if you're having a problem and describe it with as much detail as possible, good luck and be patient someone will answer your question.
Old Nov 7, 2015 | 12:07 PM
Go here to find the 2004 Service Manual, and look at Section 21-327
This is there with pictures. It is in the electrical control plate in the bottom of the transmission.
PARK/NEUTRAL CONTACT
The park/neutral contact (4) is located in the shell of the electric
control unit and is fixed to the conductor tracks.
Its purpose is to recognize selector valve and selector lever
positions “P” and “N”. The park/neutral contact consists of:
² the plunger (2).
² the permanent magnet (3).
² the dry-reed contact (4).
Last edited by onehundred80; Nov 4, 2019 at 09:42 AM. Reason: Link to 2004 manual was wrong.
Old Nov 4, 2019 | 01:10 AM
dscrossfire's Avatar
I have the same question as to where the neutral safety switch is in a 2004 Crossfire? Any recommendations on a mechanic to address this issue in the Denver area?
Thank you
Old Nov 4, 2019 | 09:43 AM
Thank you
See post #3, I have updated it to make it cleerer.
Old Nov 6, 2019 | 05:36 PM
g wheels's Avatar
Smile Re: help me / where is the neutral safety switch in my chrysler crossfire
I know you've heard this many times, but it makes me feel righteous to acknowledge that you are one helpful person!
Old Nov 6, 2019 | 05:55 PM
No thanks required, just send money.
Old Nov 7, 2019 | 06:32 PM
g wheels's Avatar
Cool Re: help me / where is the neutral safety switch in my chrysler crossfire
I was thinking of putting some cash in a can and sending it ,, you can bury it in your back yard with the other cans..
Last edited by g wheels; Nov 7, 2019 at 06:34 PM. Reason: fixing diction .. always
Old Nov 24, 2019 | 11:46 AM
sending prosperous prayers your way.
Additional question. Are the symptoms of a neutral safety problem the same as the RCM where car does not crank? Scouring these pages and others it seems that my issue was the RCM, which was repaired by DJ, but it has 4 times since the RCM repair more than a month ago also not started. But it does start when put in neutral. I don't think it is the Crankshaft Position Sensor or the Camshaft Position Sensor since it appears that the car begins to start and then dies as the symptoms for those. Is that correct? I don't see many posts on the neutral safety switch and I want to be sure that this is the issue before I send my mechanic down this road.
If so, does this repair require pulling the tranny? Any sources for a new switch?
Thanks in advance.
Geechee1962
Aug 26, 2024 08:58 PM
Vipor3D
Nov 10, 2015 09:36 PM
glover
Oct 23, 2015 10:42 PM
mcrodgers2
Oct 22, 2015 04:50 PM
BisB
Oct 11, 2015 12:15 PM
