throttle surges in park
Old Nov 6, 2015 | 05:56 PM
gblack32's Avatar
Default throttle surges in park
hi all so i was doing some repairs on the car and when i finished i went to take the car for a drive to make sure all was well. first of all when i connect the battery my running lights come on and stay on even with the headlight toggle in the off switch so im not sure what that is about but my main problem is when i start the car the rpms are going up and staying up much higher than they ever have before and when i switch from park to reverse or drive they surge up as well. the worst is when i go from drive back to park as they started going up over 3k and i turned the car off before they could go any higher. now im wondering if it is the throttle sensor or if maybe i have a vacuum leak. i took a video of it and will attempt to post it. thanks for any advice guys.
File Type: mov
Old Nov 6, 2015 | 06:24 PM
velociabstract's Avatar
Default Re: throttle surges in park
If it was normal before the repairs then you did something to cause this. Calmly review all you did during the work. Vacuum related would be my guess.
Les
Old Nov 6, 2015 | 06:29 PM
gblack32's Avatar
yea i would imagine i did it myself but the only things i took off were the k&n filters to the dcai and took the fan out. also changed the supercharger oil but dont see how that would cause a vacuum leak. generally how things have been going with this car, i fix one problem but during that repair i break something else or discover something new. its a good thing i like this car and learning about it otherwise it would have a new owner. i will check for leaks and report back thanks veloc.
Old Nov 6, 2015 | 06:48 PM
The only hoses in the area are for the air injection on each cylinder bank and I don't see how that would make the engine rev moving from park to reverse. Just be cool and take a calm long look and I'll bet you find the cause. I'll be doing some regular maintenance to my car tomorrow and I'll see what If I spot a possible reason.
Les
gblack32
Apr 21, 2018 10:33 PM
Mackel
Nov 4, 2015 07:09 PM
burnzboy2
15
Nov 1, 2015 02:17 PM
+fireamx
Oct 18, 2015 12:54 AM
Display_Name
Oct 14, 2015 10:55 PM
