Fog Lights Flash when car is in park and doors are locked
Old Nov 14, 2015 | 06:41 PM
skeet370's Avatar
Default Fog Lights Flash when car is in park and doors are locked
Hello,
Any idea what could this problem be? Fog Lights flash when the car is in park and engine is off. i have to leave the vehicle unlocked.
Skeet
2004 Fire
Old Nov 14, 2015 | 07:58 PM
Default Re: Fog Lights Flash when car is in park and doors are locked
Check the locking pump module under the trunk floorboard for any water intrusion.
Old Nov 15, 2015 | 08:09 AM
skeet370's Avatar
Will that cause the fog lights to flash? What does it look like?
Old Nov 15, 2015 | 08:51 AM
Yes, it will. It is wrapped in a foam box and looks like :
2001 2004 Mercedes SLK320 R170 Central Locking Lock Vacuum Pump Assembly | eBay
Old Nov 19, 2015 | 08:05 PM
vern66's Avatar
Originally Posted by skeet370
Hello,
Skeet
2004 Fire
I have the same problem.
Old Dec 12, 2015 | 03:08 PM
nhmercracer's Avatar
That's the alarm module failing
Old Dec 13, 2015 | 12:36 AM
skeet370's Avatar
Hello,
Where is it located in the vehicle and does it need to be replaced?
Skeet
Old Dec 13, 2015 | 07:37 AM
Travish's Avatar
Hello,
Skeet
It's under the cowl beneath the wipers. Here is the thread.
https://www.crossfireforum.org/forum...rm-module.html
And batteries
http://www.batteriesinaflash.com/plc...-pin-connector
Old Dec 13, 2015 | 07:51 AM
That is the location of the siren, the security module is incorporated in the pump that operates the locks.
When it gets wet it goes haywire, I guess it can go haywire for other reasons as well though. Unless you are lucky they can get pricey.
You have to remove the carpet and the passenger side trunk side panels and the rear trunk liner. You wold probably have to strip all the trunk pane from the car. Others have just cut the foam block covering the pump in pieces to a
Chess the pump.
Before doing this though see if there is actually any dampness in the trunk well where the pump sits.
gblack32
Apr 21, 2018 10:33 PM
Mark SRT6
Dec 17, 2015 04:24 PM
Fla_Xfire_SRT
Nov 3, 2015 01:04 PM
39lasalle
Oct 22, 2015 07:51 PM
atdavis2
Oct 21, 2015 02:25 PM
