Information on our differential
Old Dec 15, 2015 | 08:45 PM
Default Information on our differential
we have two different gear ratios and yokes in the crossfire from the factory.
SRT has 3.07 ratio and it has the larger yoke,
the diff housings are the same so this can be interchanged (not the yoke)
Limited has 3.27 gear and it has the smaller yoke
example if you wanted to put a 3.27 diff into a srt6 you would start by removing the yoke get a new squish washer and re torque it with the srt (larger) yoke . now you will need to program your tcu to the new gears.
with the 6 speed Limited you do not need the tcu programmed because there is no tcu in the 6 speed cars ,,you would need to get the correct axles and the yoke . the yokes are small 3 1/2" the large 3 3/4"
you see some cars came with two piece axles ,,and some came with one piece axles. the two piece goes for the limited ,,the srt came with one piece axles yoke%20small%20from%20limites_z.jpg?1450227427708&1450227429495&1450227432738&1450227434156
here are some pictures for you yoke%20large%20for%20srt%206_zp.jpg?1450227427707&1450227429495&1450227432709&1450227434156this diff uses the one piece axle start reading here !!!!!#5,6,7.& 3 make up the two piece axle with the #5, C-clipped in the diff. and 6,7,& 3 are factory assembled//////////the one piece axle to the left is a the Crossfire srt
this is the axle stub that some crossfires come with and the is the two piece axle
here is how to remove the differential and the axles,,
https://www.crossfireforum.org/forum...removable.html
Old Dec 16, 2015 | 10:38 AM
Default re: Information on our differntial
how to remove and reinstall your diff.
1 drain the oil
2 take all the arms loose, not the lower control arm,
3. take the brake caliper off the rotor, tie it up.
4 with the shock loose from the lower control arm
5 remove the axle nut at the rotor
6 pull the rotor down and to the left or right so the axle will come out of the rotor
7 remove the bolts on the driveshaft center bearing let it float
8 remove the bolts on the driveshaft flex coupling, pry the drive shaft out of the diff.
8 put a brace under the diff or have someone hold it up as you remove the two bolts at
the rear of the diff, remove the bolt at the front of the diff.
9 remove the diff.
10 reverse the steps to reinstall the diff. use only the oil recommended by unatrx
Old Dec 16, 2015 | 10:04 PM
boostmonkey's Avatar
Default
Awesome of you to post this to help out anyone changing their differential, axles, or gears!
Old Dec 22, 2015 | 07:55 PM
AndyJ's Avatar
Default Re: Information on our differntial
If the SRT differential were installed in a Limited 6 speed, by how much would the RPMs go down at 70 mph? Any idea how to calculate this?
Old Dec 22, 2015 | 08:26 PM
Padgett's Avatar
I am told my '07 Limited 6-speed has the one piece axle. (see picture)
The formula is (RPM * 1/2 Loaded wheel diameter) / 168 (don't ask) * gear ratio * axle ratio) = MPH
Formula is the same for an automagic when locked up. Unlocked the RPM is about 300-500 rpm higher at the same speed when above stall.
Old Dec 23, 2015 | 10:20 AM
pioneer4x4's Avatar
Yes, simple math, just divide 3.07 by 3.27 and multiply that by whatever RPM you see now.
Say at 60 you have 2200 (just a close guess/example) 2200*.94=2068 or if you like dividing 2200 / 1.065 (rounding...) 2065
You don't need to do any tire size, gear ratio calculations, you only want to know the difference, basically %6½ less RPM, simple as that.
Or if you want to see the difference at the max, at 150MPH it will be somewhere about 350 RPM less from 5500 down to about 5150, but then, maybe you won't have enough torque to the wheels to get to 150...
Old Dec 23, 2015 | 03:53 PM
Padgett's Avatar
OK, OK I yield. Here is the spreadsheet I use for the Crossfire If you do not have Excel,, Open Office can handle an .XLS & is available for many platforms. Each group is independant so you can model many things.
Fortunatly very low profile tires do not grow much at speed. (thought I posted it before)
These are not big changes, the 2.87 only drops my 70ish mph cruise on the pike by 300 rpm OTOH that is 14% less internal and drivetrain losses.
File Type: xls
Old Dec 28, 2015 | 08:23 PM
AndyJ's Avatar
Default Re: Information on our differential
Thanks for the replies. Padgett, where did you get or build a 2.87 that works for the Crossfire?
My knowledge on the topic of differentials limited obviously.
Old Dec 28, 2015 | 08:36 PM
I built it for him, would you like one? with the 6 speed we do not need a tcu ,,,I build it and u bolt it in put oil in it and GO
the cost is . + shipping
Old Jun 7, 2016 | 10:54 AM
Thanks to ECO for the picture i have added the location of the number on the differential that tells you the rato of your car's rear end. all you have to do is scrape off the dirt and grime , the number is stamped on that tab. jim
Old Nov 13, 2019 | 10:28 AM
CrossDrift's Avatar
HI @amx1397,
Could you please upload the pictures again to see the differences between a 2-pieces and one single piece axles?
Thanks!.
you see some cars came with two piece axles ,,and some came with one piece axles. the two piece goes for the limited ,,the srt came with one piece axles Attachment 39721
here are some pictures for you Attachment 39722this diff uses the one piece axle start reading here !!!!!#5,6,7.& 3 make up the two piece axle with the #5, C-clipped in the diff. and 6,7,& 3 are factory assembled//////////the one piece axle to the left is a the Crossfire srt
Old Nov 22, 2019 | 07:42 PM
performanceisland's Avatar
I would like to see the difference as well. when looking at pics on bay, I can't tell the difference. First pic shows two from a limited so should be two piece, the second and third pic of the single ones is from SRT-6 so should be one piece, other then a possible weld mark on the shaft of the SRT-6 I don't see a difference at all.
Limited
SRT-6
SRT-6
Old Nov 22, 2019 | 08:19 PM
well this post was for the removable of the rear end, but i will let you know about the axles,, read this
https://www.crossfireforum.org/forum...t=larger+axles
and yes the srt and limited axles interchange,, only were the 04 crossfire came with a two peice axle
Old Nov 23, 2019 | 09:13 PM
Is that last picture for the SRT-6 axle (the abs/reluctor ring) coming off? Or is it loose and able to be tightened.
Old Sep 16, 2024 | 03:47 PM
Up date on the wavetrac and some torque numbers
There is really only one oil
to avoid: RedLine Oil (any type)
We recommend:
Motul 300
Synergyn Syngear II
80/140
Fuchs Silkolene SYN5
75/90
We are testing Royal
Purple 85/140 this summer and looks like it will be a good one,
too.
correction on the Royal Purple gear oil... 'Max Gear' 75-140w
I just read the bottle again and it specifically states that it has 'friction modifiers'....
DO NOT USE THIS OIL for your Wavetrac LSD...
they recommend using Motul, Royal Purple wouldn't be an issue. He just doesn't want
people running Lucas oils or the other sub-tier gear oils in there.
- Torque settings
o Rear diff bolts – 84 ft/lbs
o Front diff bolt – 33 ft/lbs
o All suspension bolts – 52 ft/lbs
o Driveshaft bolts – 44 ft/lbs
Old Mar 6, 2026 | 11:10 PM
Update on changing the rear end ,(differential)
1 remove the drive shaft (at least the rear 1/2 remember to align the notches when reinstall)
2 install a jack under the rear end ( diff)
3 remove the three bolts that hold the diff.
4 lower and nose dive the diff to the left or right, (hard/push it ) this will let u get the axles out
5 lower your jack / diff it is out
6 now reverse that to install diff back into the car
note ::You do not have to remove any control arms you don't have have your car realigned simple job about 1 to 1.5 hours.
amx1397
Jun 15, 2022 10:57 PM
amx1397
Mar 31, 2018 09:32 PM
gblack32
May 13, 2017 08:32 AM
amx1397
Feb 21, 2016 11:59 AM
amx1397
Jan 7, 2014 02:03 PM
