Heater noise!
Old Dec 20, 2015 | 02:16 PM
tropixcale's Avatar
Default Heater noise!
Hey guys. Update on the rcm. Since I have beefed up the solder points have experienced zero stalling on that front. But now it seems when I start my heater in the morning or when the cars cold I get a high pitched grind/ whine that eventually goes away. I'm not losing aNY heat or cold air but the noise is very unsettling as I relocate to denver this next month. And def don't need to experience heater problems. Any ideas? Thanks as always for the speedy responses
Old Dec 20, 2015 | 02:27 PM
Default Re: Heater noise!
Where does the sound come from? Could it be debris in the heater fan/filter area?
Old Dec 20, 2015 | 02:31 PM
tropixcale's Avatar
Can't exactly say as I can't get it to grind long enough to hear it but I cleaned that box you're talking about yesterday to no avail. I may have to post a video some how. It almost sounds like the bearings in my ac compressor are dry. I have no idea. Just want and need to tackle this before the move north
Old Dec 21, 2015 | 06:05 AM
daveesrt6's Avatar
Squealing belt? mine started this noise briefly yesterday ,i sprayed a little WD40 on it andthe belt went quiet again.
Old Dec 21, 2015 | 06:31 AM
tropixcale's Avatar
Very possible. I haven't tinkered much down there but I'll tear into it today. Where was the belt located
Old Dec 21, 2015 | 07:10 AM
You want your serpentine belt to be as clean as possible and recommending that WD-40 be sprayed on it is not to be endorsed.
Old Dec 21, 2015 | 08:01 AM
tropixcale's Avatar
Well I own belt cleaner so I would be using that😀😀
Old Dec 21, 2015 | 08:28 AM
I would not even use that, if the belt is a problem then you should get a new one. How many miles on the car? Does it look like the original?
This is not your granddads car, these belts are made to last a long time without any special treatment.
Old Dec 21, 2015 | 09:12 AM
tropixcale's Avatar
I haven't been in there other than to clean the debris from the fan area. I'll pull the cabin filter and check the belt after work. It very well could be my ac compressor bearings.I'll try n post a video. The car has just over 66k on the dash
getshawty
Dec 1, 2020 08:03 PM
mymaterick
Mar 2, 2016 09:59 PM
dedwards0323
Detail Shop
Dec 27, 2015 06:27 AM
Rjono
Dec 14, 2015 11:48 AM
eatmycrackers
Dec 12, 2015 06:33 AM
