signal light trouble shooting!
Old Jan 15, 2016 | 10:14 PM
summerstar's Avatar
Question signal light trouble shooting!
So i Turn on the Emergency light today for short period, wasn't able to turn it off at once. After turning of the emergency light off, i found i can't turn on signal light at all. however, it only work when I'm holding emergency light button.
I tried killing my battery, no success or any change in condition.
What should i fix or replace to solve this problem?
Old Jan 15, 2016 | 10:58 PM
JSK's Avatar
JSK
Default Re: signal light trouble shooting!
Were the flashers still working when you turned them off, do they work now? Are batteries in season there? Do you need a tag?
Old Jan 16, 2016 | 03:18 AM
summerstar's Avatar
No, front and rear signal light and indicator arrow doesn't work all togther. Unless I hold down emergency light.(hold firm without releasing it)
also, emergency light only turns off after more than 8 push. (button light turned off, but it keep flash)
Old Jan 16, 2016 | 03:21 AM
summerstar's Avatar
signal light works only with emergency. turn light **** only activates when holding emergency button.
I replaced my battery 2days ago.
Old Jan 16, 2016 | 08:31 AM
Well, here is the schematic ( if it helps ).
I for one cannot figure out how the BCM and hazard switch interact ...... ( "turn signal monitored ground" ? )
Maybe F4 in the ICM is blown ?
Old Jan 16, 2016 | 10:43 AM
JSK's Avatar
JSK
If F4 were blown I don't think he would have any lights by holding down the switch. If that switch is readily available I think I would swap it out. He says he has to push very hard on it and press it multiple times to turn it off.
Old Jan 16, 2016 | 12:30 PM
Would this be for the light out indicator to go on if there is no complete circuit sensed?
Electronically I am a dunce.
Old Jan 16, 2016 | 07:10 PM
summerstar's Avatar
After replacing fuse, the signal light works again. I saw some other people saying replacing F4 does not help on other thread, that was because on SRT-6 F4 fuse is located on F9 location according to that picture which i also saw on previous thread.
However, i still need to try multiple push to turn off panic button
when i un-press the panic button, the light on button goes off, but it still flash on indicator and bulbs.
If i turn off the engine, un-pressing panic does not turn off the button light also.
Old Jan 16, 2016 | 07:15 PM
summerstar's Avatar
On srt-6, spare fuse was on top row of ICM which made me to think my ICM box was upside down, resulting replacing F-9 fuse. It was no success of course, so i read the chart and replace the fuse into right location and made success on it.
Old Jan 17, 2016 | 09:02 AM
Glad I could help, sorry the chart was wrong. I just copied it out of the service manual .....
dobermann
24
May 8, 2018 01:19 AM
barks
May 13, 2016 07:14 PM
chili
Feb 14, 2016 01:30 PM
summerstar
Jan 15, 2016 10:11 PM
steps
Dec 29, 2015 11:03 AM
