Not starting
Old Mar 12, 2016 | 08:30 PM
AWM08's Avatar
Default Not starting
I bought a 2006 Crossfire in November. About 10 days later it would not start. I did a little research and found that the trouble is often with the ECM. I had the points soldered and it then ran fine. Now it it is not starting again. Could this be the ECM again already or is it more likely something else? I drove to work without incident. When I left to go to a meeting, it started, went a few feet and then stalled and I haven't been able to restart. I had the battery checked and it was fine. Any suggestion?
Old Mar 13, 2016 | 12:33 AM
JSK's Avatar
JSK
Default Re: Not starting
I think you mean RCM not ECM. Possibly burnt or bad fuel pump relay inside the RCM.
Old Mar 13, 2016 | 10:01 AM
AWM08's Avatar
Would it be good just to replace the whole unit and if so should
I get one from a Mercedes clk instead. I was told that Mercedes did a recall for this issue and Chrysler did not.
Old Mar 13, 2016 | 10:03 AM
Either that or send yours to DJ ( tighed1 ) and he will replace the relay and test.
( all for @ $20 )
( I spent many months in Dayton in training back when I was with NCR,
last September I had my 50th anniversary with :
National Cash Register, then NCR, then AT&T, then NCR again, now Teradata.
Teradata is no longer affiliated with NCR after the split, but my service time rolled over )
Old Mar 13, 2016 | 10:04 AM
We should not assume that it ever was the RCM. There are other parts that work on and off before finally dying.
Does the starter make the engine rotate or not, can you hear a fuel pump when you turn the ignition key to the first position.
Give as much info as you can and you will get better help.
Old Mar 13, 2016 | 10:11 AM
^^^^ what he said. He's old like me, but unlike me, he's usually right.
onehundred80
Sep 26, 2025 12:38 PM
DTMenace
Mar 12, 2016 08:51 PM
BWilson
Feb 27, 2016 11:07 AM
hcloseuk
Feb 8, 2016 08:07 PM
Craig73
U.K.
Dec 26, 2015 10:14 PM
