Cooling system - how to open valve
Old May 4, 2016 | 07:33 AM
bigblock427's Avatar
Default Cooling system - how to open valve
Hi,
below the colling radiator is a valve. The workshop manual says you should open it to flush the cooling system (i want to replace the water pump).
Is there a trick to open it? I didn't want to break it - really tried hard, but it won't open.
Thanks
Old May 4, 2016 | 07:55 AM
Default Re: Cooling system - how to open valve
No, no trick. It must just be stuck.
I drained mine about 3 years back and had no problem opening it, just used a large screwdriver like you did ( from the picture ).
It was normal right hand thread as I recall, but my recall ain't what it used to be.
Old May 4, 2016 | 08:50 AM
Speedy4x4's Avatar
Default
Originally Posted by bigblock427
Hi,
Thanks
When you take off the water pump and lower radiator hose, it will drain.
Changed my water pump in parking lot last night after work.
Old May 4, 2016 | 10:17 AM
kingdavid54's Avatar
You are correct, just did mine a couple of months ago, righty tighty lefty Loosey.
NetChain
Sep 25, 2016 03:13 PM
stz561
May 1, 2016 08:25 PM
Bayukbros
Apr 21, 2016 02:00 PM
jthaub
Apr 19, 2016 06:47 PM
Rameriz
Apr 19, 2016 03:06 PM
