How can glued on body panels be removed?
Old Jul 20, 2016 | 04:45 PM
JAG's Avatar
JAG
Default How can glued on body panels be removed?
I have a 2005 Crossfire SRT6. It was damaged on the driver's side. To do the repair, panels that are spot welded and glued need to be removed. Is there a way to remove/dissolve the glue so that the parts can be taken off?
thank you,
Old Jul 20, 2016 | 05:59 PM
Default Re: How can glued on body panels be removed?
thank you,
Drill out the spot welds and heat the bonded area. I am not sure how much heat is required though.
Dees4
Jan 24, 2023 07:26 AM
helosixx
Jan 17, 2016 10:22 AM
twboyle
Jan 1, 2016 03:03 PM
Bifftws
Dec 30, 2015 03:39 AM
imported_mightyjlr
Dec 3, 2003 06:06 AM
