replaced CPS, did the RCM repair, STILL shutting off.
Old Sep 14, 2016 | 01:18 PM
Hal B's Avatar
Cool replaced CPS, did the RCM repair, STILL shutting off.
Thanks for all the great info to assist me in my common issue of engine shutting off. I replaced the CPS, and sent the RCM to tighed1 for his upgrade and repair, and she left me on the side of the road yesterday again.
Any other fixes to suggest to my mechanic? Don't like it when he says "I'm going to have to research this issue".
Old Sep 14, 2016 | 02:03 PM
Default Re: replaced CPS, did the RCM repair, STILL shutting off.
non-diesel engines stop for 3 reasons :
1. They broke something important internally.
2. they have no fuel.
3, they have no spark.
Next time it quits, see if it will crank over.
If it will, then unplug one of the plug wires at the coil pack and hold it close to the socket while trying to start. If you see spark, then you have a fuel problem. If not, then most likely a CPS connection or some other PTCM signal is bogus.
You can also see if fuel sprays out from the test port on the front of the fuel rail when you depress the Schrader valve. That will indicate you have fuel pressure.
Old Sep 14, 2016 | 03:11 PM
Mackel's Avatar
On behalf of Pizza Guy...did you replace the CPS with a BOSCH CPS?
Old Sep 14, 2016 | 03:21 PM
Hal B's Avatar
I am going back to my receipt from the mechanic that replaced it to find out. That important?
Old Sep 14, 2016 | 03:31 PM
tighed1's Avatar
By chance does the radiator fan spin up really fast when the car cuts off?
Have a RCM in my hands now that checked out ok, but the owner says that the car cuts off once he drives a bit. Did the usual repairs and instead of mailing it back I stuck it in my car and drove it to work today. Got about 5 miles and she died. Fan spun up.
BAM! Engine control relay.
Will replace that tonight before returning to owner.
Old Sep 14, 2016 | 03:35 PM
Mackel's Avatar
Quoting Pizzaguy here...
"Did you go to Autozone or NAPA and buy some generic off-the-shelf sensor? Or did you order the RIGHT PART?
Here is the RIGHT PART:
https://www.germanautosupply.com/sto...sensor-96.html
I have carried one for five years, when mine died, I put the spare in and ordered another. They are not easy to find locally - and this has come up several times before - those generic sensors do not ALWAYS work and they do not always NOT work - you just never know with them."
Hal B's Avatar
Haven't noticed, been too stressed out when it dies in traffic to notice. She seemed to do fine once I get the RCM back from you, put on about 20 miles on it before it started cutting off again.
Old Sep 14, 2016 | 03:39 PM
Mackel's Avatar
If your mechanic used a Bosch CPS then my money is on TIGHED1's diagnosis.
Old Sep 14, 2016 | 03:42 PM
tighed1's Avatar
Notice next time. LMK
Old Sep 14, 2016 | 03:45 PM
Hal B's Avatar
After it "cooled off", started up again. Let it sit and idle over 5 minutes, nice an smooth. Reved to 3K RPM, cut right off. Will go back and try again and listen for the fan
Old Sep 14, 2016 | 03:56 PM
Try disconnecting the CPS, spray both the connector and the CPS with contact cleaner, let it dry and reconnect.
Another thing that might help is a SLIGHT twist on the 2 pins in the CPS connector, this will ensure a better contact from the connector.
Old Sep 15, 2016 | 09:37 AM
tighed1's Avatar
Haaaaallllllll!
Fan, no fan?
Old Sep 15, 2016 | 10:34 PM
Billto's Avatar
DJ, you ARE the man.
Old Sep 18, 2016 | 04:02 PM
lovecross's Avatar
Question Re: replaced CPS, did the RCM repair, STILL shutting off.
Haaaaallllllll!
Fan, no fan?
Hal; inquiring minds are trying to help...update please.
My first crank sensor change, in parking lot @ dusk, I broke the connector clip. Worked fine for a day or two, then stalled again. I think the connector worked itself a bit loose, maybe enough to cause a problem. After that, I installed a Bosch cps, making sure of a secure connection AND installed a new RCM for extra insurance. Just my 2 cents.
Thanks tighed1 for your efforts for all. I should send you my original RCM so I have a back-up.
KUJhawk
Aug 10, 2017 01:51 PM
roychez
Oct 27, 2016 09:43 AM
silamanajik
Sep 11, 2016 11:37 PM
NovaCharged
Sep 10, 2016 07:21 PM
Michael11
Sep 8, 2016 04:11 PM
