A lot of issues after taking apart the interior
Old Oct 24, 2016 | 04:37 PM
thedarkfox's Avatar
Default A lot of issues after taking apart the interior
OK- I took out my passenger seat, the headliner and the center console to re-finish them all as they had some wear. My airbag light is now on because I forgot to plug it back in before starting but that is no big deal. The issues are:
  • Brake light stuck on
  • Bas ESp Light On
  • and for some crazy reason my overhead lights will not turn off in any way shape or form, not with the switch or even when everything is closed.
  • Intermittently the blower is still blowing when the key is out.
Does anyone know of any solutions for these issues?
Thank you
Old Oct 24, 2016 | 06:50 PM
Default Re: A lot of issues after taking apart the interior
You didn't disconnect the battery ground cable before you started this work, did you?
Old Oct 24, 2016 | 07:15 PM
thedarkfox's Avatar
Yes I actually did. The only thing I forgot was to plug the airbag back in before I reconnected it and turned on the key
Old Oct 24, 2016 | 10:37 PM
JEFASOLD's Avatar
Well, you obviously did something wrong! Start over, make sure everything is plugged back in correctly, clean connectors, etc. As I have stated in the past, it's amazing how many times problems arise just after the owner has done a mod or maintenance, the cars seldom just go bad.
Old Oct 25, 2016 | 04:15 PM
One thing that JUMPS right out at me, previous post alluded to it. Could you have PINCHED a cable or harness while reassembling? If you 'ground' or 'short' things in a pinched area, it could play he!! with figuring it out. So, take out the things with cables/harnesses and reconfigure/check the routing when reinstalling. IF there is a pinched wire/cable, you have to check it is a reliable connection where it is supposed to go (not cross connected, if wires are broken into). Good luck!
Old Oct 25, 2016 | 06:14 PM
thedarkfox's Avatar
Fixed the brake light as it had indeed popped out, the interior light is still eluding me. it looks like the metal tracks moved but I can not tell whether they are supposed to be touching or not supposed to be touching. There are little metal points in between the tracks. Does anyone know whether they should touch or not?
