How to Secure Courtesy - Dome - Map Interior Bulb in a Broken Board
Old Nov 29, 2016 | 03:19 PM
BobG's Avatar
Default How to Secure Courtesy - Dome - Map Interior Bulb in a Broken Board
One of my courtesy bulbs was dimmer than the other, so when I went to replace both with LEDs I discovered that somehow, some time in the past I had broken part of the plastic board that holds the bulb. The bulb was loose. Ugh.
Solution: Use cable ties to secure the bulb.
Old Nov 29, 2016 | 05:52 PM
Default Re: How to Secure Courtesy - Dome - Map Interior Bulb in a Broken Board
My solution was a hot glue gun. Same results.
Old Nov 29, 2016 | 06:25 PM
2005 Ragtop's Avatar
ala_xfire,
Okay my drivers side map light is exhibiting all the standard problems cited in the various relevant thread(s). Purchased a hot glue gun and am ready to repair. What specifically gets glued on the fixture. Last thing I need is to go in and apply glue to areas it doesn't need to be applied to. My understanding (feeble as it is) is that the metal run to the socket needs to be glued down. Correct ??
Old Nov 29, 2016 | 07:20 PM
Correct. The metal runs separate from the board, use the hot glue liberally EXCEPT where the bulb sockets make contact.
Hold pressure on the runs against the board while applying.
Old Nov 29, 2016 | 08:53 PM
waldig's Avatar
Talking Re: How to Secure Courtesy - Dome - Map Interior Bulb in a Broken Board
I like crazy glue and accelerant as it is stronger and not heat sensitive. Cheers Woody
hardens is 1-2 seconds so its easy to work with.
Old Nov 30, 2016 | 12:27 PM
Ala, Waldig,
Many thanks for the feedback !! As the map light fixture is a subassembly of the $2200.00+ Home Link Module and NOT available separately I NEEDED input on what gets glued before turning the fixture into a completely inoperable wad of glue.
Old Nov 30, 2016 | 12:32 PM
Ala,
One additional "Oh by the way". Approximately how long will it take for the glue to set to the point I no longer need to apply pressure to the metal run/contact ?? Thanks again !
Tim
Old Nov 30, 2016 | 12:35 PM
About 15 seconds. "Hot glue" is really melted plastic, takes no time to cool and solidify.
Old Nov 30, 2016 | 12:42 PM
Ala_Xfire,
You sir, ROCK !!! Thanks so much. This caveat "EXCEPT where the bulb sockets make contact" will doubtlessly spare me an AWWW $hit.
Tim
Old Nov 30, 2016 | 01:11 PM
BobG's Avatar
Nice solution, but in my situation I had broken off one of the plastic lips that lock the bulb socket to the board, so glue by itself would not have solved the problem.
