MOMO shift knob
Old Mar 18, 2005 | 06:08 PM
former NXMX5's Avatar
Default MOMO shift ****
finally got around to taking some pictures of the car... heres the shift **** i put on. Momo Race Aluminum. ebay, $62.90, free shipping from shopmomo (www.shopmomo.com) NOT affiliated with this company whatsoever, just passing along info.
Old Mar 18, 2005 | 07:02 PM
Epyon
Guest
Posts: n/a
Default Re: MOMO shift ****
nice, what radio is that?
Old Mar 18, 2005 | 07:49 PM
its a JVC KD-LHX500; JVC is actually releasing a new version soon named the 550...
http://www.cardomain.com/item/JVCKDLHX550
first the crossfire gets discontinued; now my head unit... doh.
Old Mar 19, 2005 | 09:03 AM
andrew's Avatar
-C-I-C-C-I Associate Member
that looks really nice!
Old Mar 21, 2005 | 10:34 AM
Panzer1's Avatar
I liike the radio, any problems installing it, I hear its hard to change the head on the XF. ??
Something about the pre-amps ??
Old Mar 21, 2005 | 01:58 PM
no, its not hard at all. and yes i did use the pre-outs instead of the speaker outputs. the XF has an external amplifier separate from the stock head unit.
you will need a Scosche VW01 wiring harness adapter and a Metra 40-EU10 antenna adapter.
Old Mar 21, 2005 | 02:24 PM
Panzer1's Avatar
Cool ! I like the look and I was looing at the 550, not much different ?!
So if I use the pre-out it should not create the distortion everyone has been talking about ?!
Or kiil the OEM amp.
What a load of crap, you buy a car like this, they charge you 800 for the radio and you wind up change it it !!!
Thanks for the info !
Old Mar 21, 2005 | 11:49 PM
dariushashrafi's Avatar
Hi
I heard it is very hard to take the **** out!!! how did you take the stock shift **** out.
thanks
Old Mar 22, 2005 | 02:36 PM
thats not hard either. pull up on the shifter surround and youll expose the shifter. theres a plastic nut that hold the **** on. unscrew it and wiggle the **** and itll come off.
Old Mar 22, 2005 | 03:17 PM
mhorn's Avatar
Did you have any problems installing the shift ****? Did it just slip right on?
Old Mar 22, 2005 | 07:49 PM
the shift **** came with 5 or 6 inserts, depending on the diameter of the shifter. slip the best-fitted rubber insert on the shifter and push the **** down. tighten the three set screws, then screw in the base (under the boot). this was the toughest part, because i wanted to get the shift boot in there evenly and tight. probably took about 15 minutes.
Valk
Jul 12, 2021 09:49 PM
crossfireusa
Oct 28, 2015 12:03 AM
jimf
Oct 10, 2015 10:22 AM
Crossfireone
23
Aug 25, 2015 04:56 AM
Cuda56
Aug 11, 2015 12:11 PM
