Aftermarket Stereo Audio Quality
Old Apr 10, 2017 | 04:19 PM
coryforman's Avatar
Default Aftermarket Stereo Audio Quality
After replacing my stereo 3 times, I ended up with a Kenwood Excelon KDC-X500 Stereo. The previous 2 were Pioneers and I returned them as the audio quality was terrible. I went with the Kenwood because someone on the Facebook group helped me figure out my main issue was the RCA output level was not powerful enough for the stock amp.
The audio quality is better... but I feel like it's still not what I'm expecting it to be. The OEM stereo would have so much bass, my rear window would rattle. I've tried changing almost every setting I could find and tried the "replacing it was the stock radio, level everything out, put the aftermarket stereo back in" and no luck. I also tried using the output converter which seemed to make things a little better, but still not what the OEM stereo provided.
Does anyone know what I'm missing to get that sound quality back?
Old Apr 10, 2017 | 10:10 PM
Padgett's Avatar
Default Re: Aftermarket Stereo Audio Quality
Dunno, the Clarions I have sound much better than Satellite and never want more than 1/2 vol.
It is strange that the amp only uses front L&R so need to bias accordingly unless rewired.
Old Apr 10, 2017 | 10:47 PM
daveesrt6's Avatar
I replaced my Infinity hu with a Kenwood hu, speaker level out to the infinity amp and turned the output from the Kenwood down in settings.
Bass is not lacking , considering their size the woofers do an awesome job.
Are you sure the woofers are actually working ?
I dont like the ergonomics of my kenwood , its difficult to see and the buttons are too crowded. but it does Sound great and has a ton of features.
ymmv
Old Apr 11, 2017 | 07:32 AM
Speedy4x4's Avatar
Default
When I replaced my kenwood I just wired it into the harness I did not use rca, and I thought I got more bass than I had, not near enough for me, but more than I had, did the pyle replacement behind the seat, and got alittle more, then went all out with a 1200x2 amp behind passenger seat ( barely) and boxes and a large pair of 8" subs, and new components in door, with new tweeter mounted on dash beside the a pillars and have factory tweeters running normal with using factory amp and I am more than happy, have all frequencies clearly.
Good for my long drives.
there are more than 1 bass setting on kenwood unit, there is the
bass,
bass boost
and loudness.
Turn all 3 up and you will be overworking those little 6.5s.
Since you said you hooked up factory amp with rca, did you hook them up as rear rca or subwoofer rca then there is another setting on unit for subwoofer lever.
Old Apr 13, 2017 | 06:17 PM
coryforman's Avatar
bass,
bass boost
and loudness.
I'm not sure which way I connected it... but I have heard the rear speakers aren't really considered subwoofers and when I change the settings to turn the subwoofers on, I don't notice a difference.
Old Apr 13, 2017 | 06:23 PM
Speedy4x4's Avatar
Default
How do you listen to your music, radio, cd or bluetooth?
Old May 15, 2017 | 10:18 PM
Kurtp13's Avatar
I'm curious how this turned out. I ordered a Kenwood HU and I hope for better sound. Any update on your install?
Old May 18, 2017 | 07:02 PM
Speedy4x4's Avatar
Mine sounds good, but I have
Kenwood kmr-d558bt
Skar tx65c components on factory amp
Skar skv2-1500.1 amp powering
2 Skar vvx -8v3 subwoofers
