Loctite 40482
Old Apr 20, 2017 | 03:57 PM
Default Loctite 40482
Has anyone tried this RTV yet. It would appear to me that you could get the small bead required and not the blobby looking bead that is too big and probably leads to premature failure of the seal. This gets away from the need for the expensive Mercedes tool that uses their sealant. It appears that the sealant tube is reusable if resealed as they say it should be.
With this can you should be able to lay down a small consistent sized bead that just fills the groove without the excess that shows too much when it is squashed out of the joint.
It is sensor safe and appears ideal for our application on the breather covers and elsewhere. At about $19 a tube it seams a good buy.
CLICK
CLICK
Old Apr 20, 2017 | 05:19 PM
Default Re: Loctite 40482
CLICK
CLICK
Thanks Dave.
Any reason I shouldn't get the black ?
Loctite 40463 | JEGS
Old Apr 20, 2017 | 05:51 PM
bluecoupe's Avatar
If black is your preference, Loctite also has an instant gasket formula that has Daimler Chrysler MS-GF44 Grade A approval (whatever that is?)
LOCTITEŽ SI 5900? Instant Gasket - Henkel
Old Apr 20, 2017 | 08:25 PM
Thanks, but no thanks. I'm fast, but not THAT fast.
Full cure time at 77 F is 60 seconds !!!!
Old Apr 21, 2017 | 01:05 PM
Thanks Dave.
It is said to be sensor safe.
