Starts and dies...need help in Indiana
Old Apr 21, 2017 | 10:51 PM
Lon's Avatar
Lon
Thumbs down Starts and dies...need help in Indiana
I have a 2004, with 94k miles. I tried to start it after work, it started and died, it did this 3 times then nothing.
The car had the crankshaft sensor replaced, no change.
No one will work on this car.. I know it's a Mercedes...if it is the WIN sensor, can my original one be repaired? If I buy a new one, I will need the keys programed, and no one in Indiana will touch it..
Thanks.. Lon
Old Apr 22, 2017 | 12:57 AM
Mrmiata's Avatar
Default Re: Starts and dies...need help in Indiana
https://www.crossfireforum.org/forum...ule-again.html
https://www.crossfireforum.org/forum...eedswings.html
Old Apr 23, 2017 | 08:56 AM
Jim6869's Avatar
mystery no start (maybe) check youtube
Old Apr 23, 2017 | 10:07 AM
Padgett's Avatar
Ask about someone who can work on a 2004 Mercedes SLK320, drivetrain is nearly the same.
Old Apr 25, 2017 | 03:41 PM
mmcandre's Avatar
HI Lon, this happened to me and ended up being my SKREEM module. You may want to search for that and see what you come up with. Just a hint if it is, unhook your battery, remove Fuse #9 then rehook up your battery. This is a work around but will leave your security system disabled as well as you auto door locks disabled. Just sharing in case it helps.
