12vdc switched by the ignition in Dome Housing
Old May 13, 2017 | 05:02 PM
bucketlisted's Avatar
Default 12vdc switched by the ignition in Dome Housing
Is there a 12vdc switched by the ignition, circuit in the Dome Housing?
I have read the posts about picking it up in the side pillar but have not seen anything confirming if there is or is not anything upstairs, which doesn't make sense to me, because if there are wires in that side post some of them must be headed for that dome.
Thanks
Old May 13, 2017 | 05:18 PM
Default Re: 12vdc switched by the ignition in Dome Housing
Thanks
Pin 1 of the TPMS module is switched B+ on fuse #1, 5 amp, or pin 3 of the Garage Door Opener.
Old May 13, 2017 | 05:47 PM
ok, i see that, radar hard wire coming up
thanks mr ala
Old May 17, 2017 | 12:26 PM
I'm not sure which pin is #1
Can you tell from these photos?
Old May 17, 2017 | 03:10 PM
it's the one with the pink/yellow/dark green wire
Old May 17, 2017 | 06:13 PM
ok
i didn't realize that it had a connector further back in the cavity
it looks like switched 12vdc is available on the far right leg as you say
and ground would be the brown (3rd from right) ??? do ya think
Thanks
Old May 17, 2017 | 06:14 PM
Yes, as a rule, BROWN is ground on German cars, but you can always meter it be be sure.
Old May 17, 2017 | 06:23 PM
yepp, brown/ground, i have forgotten more than i will ever know
thanks for the confirmation Ala
i'll throw a meter on it to be sure like you say, don't want to fry a brand new radenso xp,lol
Old May 17, 2017 | 08:51 PM
I was looking for a switched 12 volt supply for my dash cam which is mounted behind the rear view mirror and I thought those wires looked a little too small. So I opted to go to a larger switched wire that was on the radio plug. Fortunately the dash cam wire was ample in length. The wires from the dash cam were hidden behind the upper and side windshield moldings and then through the dash to the radio.
I think everyone should have a dash cam, but be ready to toss it if you cause the accident.
Old May 17, 2017 | 09:29 PM
ok, i nailed it, perfect
i used the Radar Mount hardwire with inline fuse and I built a mount as previously done in this Forum, modifying to my taste by making it just abit longer and powder coating it.
the RadarMount wire with gold plated pins worked real slick .. plug and play
thanks for your 2 cents mr Ala
Old May 17, 2017 | 09:35 PM
good way to go, that is my next install
i thought that i read somewhere in here that there is a switched wire in the drivers side pillar, is that so?
Old Jun 2, 2017 | 02:11 PM
Kurtp13's Avatar
I saw a garmin GPS with an integrated dash cam at Costco the other day. That seemed like a good dual purpose device
Old Jun 2, 2017 | 05:13 PM
My Bluetooth Mike wire comes down behind that trim and any wires there are on their way to the underhood fuse box from the overhead console.
