HVAC fan issues
Old May 21, 2017 | 09:11 PM
maggy55's Avatar
Question HVAC fan issues
Okay my HVAC fan speed control seems to change speed on it's own, not at every speed level, but at a couple of them. It will speed up and slow down. If I jiggle the rotary dial I can get it to change speeds as well. I have removed the unit and done the repair suggested by CL770. I have also replaced the fan motor resistor. Neither fixed the issue. Any other ideas ? Is there a way to clean the rotary switch ?
Old May 21, 2017 | 09:14 PM
Default Re: HVAC fan issues
Mine does the same thing occasionally, but not enough to be concerned yet. I spin the rotary switch up and down a few times and it is ok for some time. I am sure it will get worse with time. Please keep us informed of your findings.
Thanks, James
Old May 21, 2017 | 11:26 PM
There is a fix that was posted by a new member some little while ago. Basically he said that the connection of the front plate and the PCB behind it was poor and caused trouble. I'll look for the fix and post it in this post.
Try this fix. CLICK
Old May 21, 2017 | 11:32 PM
maggy55's Avatar
I did try fix referenced in your Click Here already, thanks though.
Old May 21, 2017 | 11:55 PM
Sorry I forgot CL770 was the author.
Old May 23, 2017 | 02:03 AM
daveesrt6's Avatar
Yes i have the same issue with my HVAC .
Andrew kindly did the fix for me about a year back but its started playing up again recently.
Old Jul 19, 2017 | 11:48 PM
Joliet John's Avatar
I see some online sellers claim the HVAC control unit they have will only work in an automatic transmission car. Looking in the Crossfire parts catalog, I only see on part number listed for this part. Is there a different part number for manual cars?
Old Jul 20, 2017 | 06:21 AM
no reason why there would be two different parts.
