2004 crossfire starting issue
Old Sep 1, 2017 | 08:54 PM
chevyboyac's Avatar
Default 2004 crossfire starting issue
Hello everyone! My 2004 crossfire won't start 1 out of every 15 ish times. It will really try hard to start and just stumble for the whole start process. Then you turn the keep again and it starts fine. Anyone have this issue before? It's not throwing any codes and it has a new fuel pump and filter (I thought it was getting weak fuel pressure) and it has about 180,000 miles on it.
Old Sep 1, 2017 | 09:46 PM
Steve Jr's Avatar
Default Re: 2004 crossfire starting issue
You're on the track , I would be going in. Since you've done the pump an filter ,with the high milage(that's a factor) maybe run some Seafoam through the system to clean the injectors. Have you done a reset for the throttle? Sometimes it gets use to a driving pattern , an this would set it back , to what it should be.
Old Sep 1, 2017 | 09:54 PM
chevyboyac's Avatar
Yea i've done a injector cleaner. I will try the throttle reset. I wonder if the crankshaft position sensor might be acting up.
Old Sep 1, 2017 | 11:41 PM
Steve Jr's Avatar
That's a possibility. Its been suggested, you can remove it an clean the bottom surface , then reinstall. If your tinkering around this weekend ,try both suggestions (throttle reset , clean CPS) .Do reset first, then try the other. If it works an you haven't already changed the CPS , get a Bosch @ maybe amazon , right now they have, about the cheapest price going. Let us know how it goes...
Old Sep 2, 2017 | 07:09 AM
Steve, it's a magnet with some wire wrapped around it, it does not care if it's bottom is clean or not.
There may however be a problem with the connector, clean THIS with contact cleaner.
Old Sep 2, 2017 | 07:57 AM
Steve Jr's Avatar
Yes I understand that , but the "discussion" was saying, that over time it may build up particles an shavings of rust an debris , clinging to the magnet. Hence,, removing, cleaning, reinstalling. Its not something I would do to fix it, but I would do it to get home.
Old Sep 2, 2017 | 08:01 AM
OK, point taken. I'll shut up now.
Old Sep 2, 2017 | 08:13 AM
Steve Jr's Avatar
No, your right! The connection has caused people more problems , than anything. My thought was, he would clean that when he removed the CPS. BUT, you know what they say about ***-U-ME!...
Old Sep 2, 2017 | 09:42 AM
If the CPS was a problem then surely it would act up when driving?
Old Sep 2, 2017 | 10:34 AM
tighed1's Avatar
Could be the fuel relay in the relay control module. I've seen the relays work/not work randomly.
Old Sep 2, 2017 | 10:49 AM
chevyboyac's Avatar
Thanks for the imput guys! I have replaced the cps and reset the throttle. I will report back with results. I will check out the fuel relay etc if that doesn't fix it.
