Replacing bearing on tensioner pulley
Old Oct 21, 2017 | 05:39 PM
xodus52's Avatar
Default Replacing bearing on tensioner pulley
I pulled the tensioner pulley off of the assembly to swap out the bearing. Seems that the pulley assembly is molded around the bearing, so I can't see how it could be done without damaging the pulley (unless I'm dense and missing an obvious solution).
So now I'm looking to buy a replacement pulley but can't find any without buying a whole new assembly. Does anyone know a part # for it or a place I could purchase one? Checked RockAuto and the usual suspects with no luck.
Old Oct 21, 2017 | 08:16 PM
Default Re: Replacing bearing on tensioner pulley
Personally I would find a good price for the whole assembly and be done with it. There are more parts to wear out than the pulley bearing.
James
Old Oct 21, 2017 | 11:50 PM
You can replace the pulley by itself, it is the same pulley as the idler pulley according to one post I found. Pulleys are available at auto parts suppliers. There is nothing special about these pulleys.
