Lock/unlock system is not Working
Old Mar 28, 2018 | 01:18 PM
zalsaigh's Avatar
Default Lock/unlock system is not Working
The lock/unlock system in my 2004 crossfire is disabled due to a faulty siren which blew fuse #9. After replacing the siren, the system did not come back to function and I do not hear the pump running. I checked the pump and found it dry and unmolested. The remote fab works as usual, the lights flashing normally but the locks would not function. The lock/unlock switch at the counsel is also disabled.
Is there anything needs to be done to bring the system to work?
Old Mar 28, 2018 | 04:11 PM
Default Re: Lock/unlock system is not Working
Looking back on your previous posts I see that at one time you disconnected the pump and BCM (?) in the trunk (fuse?) and I cannot see when it was reconnected. You did say you were going to look for the hissing in the trunk in one of your last posts but you never replied.
You appear to have had an ongoing problem here that has been looked at by you on and off for a year.
You need to reply when you do something as too many people are given the solution and never say thanks or are never heard from again.
Old Mar 29, 2018 | 01:03 PM
zalsaigh's Avatar
I see you are looking for a compliment, thank you for responding. I do have an on-going and puzzling problem with the lock/unlock. The pump and the BCM were unplugged for inspection and then put back to the original condition. There is no hissing sound yet. I wrote back because I never received any satisfactory solution from any member other than schematics that I have in the shop manual. If you offer a solution, you will get a million compliments.
Old Mar 29, 2018 | 04:05 PM
I am not looking for a compliment and as of now I am not looking for an answer for you.
2006Crossfire
Sep 22, 2014 05:08 PM
murtazanooruddin
Aug 17, 2009 09:51 AM
an0nym0u5
Jul 22, 2008 05:56 AM
homer4evr
Jan 23, 2005 08:47 PM
Sunny9850
15
May 13, 2004 01:22 PM
