Pumping gas issue
Old Apr 9, 2018 | 11:44 AM
GannyX's Avatar
Default Pumping gas issue
I have trouble with pumping gas into the car.(i know gas prices are rising) but it pumps for a few seconds then stops, it takes almost 20 mins to pump 20$. Any idea
Old Apr 9, 2018 | 12:46 PM
Default Re: Pumping gas issue
turn gas nozzle upside down.
Old Apr 9, 2018 | 01:04 PM
GannyX's Avatar
I have still does it
Old Apr 9, 2018 | 01:48 PM
It is probably the valve that prevents overfilling the tank, it is stuck in the closed position.
Old Apr 9, 2018 | 01:54 PM
Steve Jr's Avatar
Is it the gas nossle kicking off? Are you seeing gas overflowing up the fill tube on your car? 2 very different problems. 1 is high pressure because ,maybe you are the only one using that product an getting full pressure from the motor suppling fuel at that pump. 2 could be a cut off at the bottom of the fill tube, but it is suppose to completely shut off the tank in case of accident. We've had discussions of this on here before.
Old Apr 9, 2018 | 02:00 PM
GannyX's Avatar
Yeah it kicking the pump off and only sometimes im seening backflow
Old Apr 9, 2018 | 02:54 PM
GannyX's Avatar
It does with all pumps,pizza was with me
Old Apr 9, 2018 | 06:47 PM
waldig's Avatar
Talking Re: Pumping gas issue
The anti theft flapper has an issue Ill bet cha. Woody
Old Apr 10, 2018 | 01:45 PM
GannyX's Avatar
How you fix it
Old Apr 11, 2018 | 10:05 AM
waldig's Avatar
Get a light and look see in the pipe, can you see an issue, stuck flapper may need to be probed with a long tool. WW
Old Apr 11, 2018 | 11:05 AM
See, I was thinking it was the vent but this is why I wanted you to post here - I think the guys may very well be right about the "flapper".
Old Apr 11, 2018 | 01:54 PM
lorne's Avatar
There is a small line in the filler neck that runs up to the charcoal canister,it is called a vent tube. If ths line is pluged or damaged you will get these symptoms when you try to put in gsa. Lorne
Old Apr 12, 2018 | 02:51 PM
GannyX's Avatar
Ill check it out in a bit how would you get to the charcoal canister?or at least the line
Old Apr 13, 2018 | 08:00 AM
waldig's Avatar
The vent tube AINT IT. That does not equalize the pressure it captures fumes for emission. Crawl under the car and also see that the fuel line has not collapsed - the big fuel tube. The fuel tank is behind the seats and your path has an obstruction either the flapper for anti syphon or fuel inlet line. Woody
Whadda u see looking inside the filler neck?????????????
Old Apr 13, 2018 | 08:25 AM
A word of advice:
^^^ This guy knows the car, GannyX. You can take what he says to be "Crossfire Gospel." ^^^
Old Apr 13, 2018 | 08:58 AM
The big fuel tube is completely inside the trunk and is not visible from underneath the car.
Old Apr 14, 2018 | 06:59 PM
GannyX's Avatar
This what i see, how would i get to the vent tube from the trunk
Old Apr 14, 2018 | 08:07 PM
KDW4Him's Avatar
Yeah it kicking the pump off and only sometimes I'm seening backflow
At EVERY station you go to?
Old Apr 14, 2018 | 08:09 PM
KDW4Him's Avatar
You should also have an emissions code if this happened.
Old Apr 14, 2018 | 08:23 PM
GannyX's Avatar
No code and every gas station, only code I throw is for egr
