Oil sensor question.
Old May 22, 2018 | 06:40 PM
blue pearl's Avatar
Default Oil sensor question.
Has anybody used the Mercedes version 0061532728 in place of the Chrysler SU6904? The price difference seems too extreme for them to be the same. The Chrysler programming could be different and therefore the sansor?
Old May 22, 2018 | 08:53 PM
zip439's Avatar
Default Re: Oil sensor question.
Oil level sensor Mercedes 0061532728 will work on the Crossfire; I believe the new Mercedes number is 2759050000.
Old May 23, 2018 | 12:33 AM
blue pearl's Avatar
Thank you.
When I do a search for the 2 the Chrysler part shows a metallic tip and the Mercedes part shows a plastic tip. I am guessing the plastic part is just a protector and is removed before install?
Old May 23, 2018 | 08:33 AM
zip439's Avatar
https://www.crossfireforum.org/forum...tml#post524674
It has been a few years since I replaced mine. I do not remember removing a plastic piece from the replacement, but there are two pieces you are dealing with, perhaps that explains the difference in the pictures you are looking at; Not a difficult job. There are instructions in the link.
Old May 23, 2018 | 11:30 AM
The assembly appears to consist of four parts according to a Mercedes parts list, but they may come as one part
Forget this I cannot make seem sensible.
NumberCntNameUsageRemarks5
A0015427218
Replaced By: A0041535328
SENDER UNIT
A0041535328
Replaced By: A0061532728
OIL LEVEL SENSOR
A0061532728
Replaced By: A2759050000
SENDER UNIT
OIL LEVEL CONTACTOR
A2759050000
FILL-LEVEL SENSOR
OIL LEVEL CONTACTOR
A0239974348
SEAL RING
17
N910143006001
HEXALOBULAR BOLT
OIL LEVEL CONTACTOR TO OIL PAN
M6X16
29
A0005425118
Replaced By: A0009050700
SENDER UNIT
COOLING WATER TEMPERATURE
29
A0009050700
TEMPERATURE SENSOR
35
A0229979848
SEAL RING
41
A0089889178
CLIP
TEMPERATURE SENSOR ON TIMING CASE
A0015427218
SENDER UNIT
A0041535328
OIL LEVEL SENSOR
A0061532728
SENDER UNIT
OIL LEVEL CONTACTOR
A2759050000
FILL-LEVEL SENSOR
OIL LEVEL CONTACTOR
A0239974348
SEAL RING
17
N910143006001
HEXALOBULAR BOLT
M6X16
29
A0005425118
SENDER UNIT
29
A0009050700
TEMPERATURE SENSOR
35
A0229979848
SEAL RING
41
A0089889178
CLIP
KDW4Him
Oct 5, 2017 10:10 PM
Buffalo-Lax35
Jul 15, 2015 05:12 PM
Billy22Bob
Oct 22, 2012 03:56 PM
mhoward0058
Feb 6, 2012 07:42 PM
oceansideaddict
Nov 15, 2010 02:41 PM
