My '04 crossfire keeps dying help please
Old Jul 18, 2018 | 01:47 AM
Bignick2323's Avatar
Default My '04 crossfire keeps dying help please
Hi i have a 04 chrysler crossfire i have had issues with the car since i bought it i can be driving it will cut off and all the dash lights will come on if i sit for 5 ten minutes it starts back up and im fine it has a new starter alternator and battery i dont lnow where to turn can someone please help
Old Jul 18, 2018 | 06:52 PM
Default Re: My 04 crossfire keeps dying help please
Can be one of several items.
  • When it quits, if it won't engage the starter at all until it has sat awhile, but when it finally does engage the starter, it starts right up, I'd say it's a bad Engine control relay on the RCM or fractured solder on the RCM. Send the RCM to DJ in Arizona for repair or order a new one online.
  • If it quits and will engage the starter and crank but won't start - I'd change the Crank position sensor.. IN this case, it could also be a bad fuel pump relay on the RCM but I really doubt that.
Old Sep 27, 2018 | 11:34 AM
Vin's Avatar
Vin
Default Re: My '04 crossfire keeps dying help please
Hi All,
I'm new to the site and I hope I am making sense here. My ,04 CC Crossfire is old fair enough with 150000 miles on the counter, but working fine.
Just a few weeks ago 'the ignition' started playing up. once or twice a week the engine starts normally when you turn the key on. Most days when I turn the key on in the ignition, it simply won't start, but the only thing that starts is that devious and progressively increasing 'humming' noise coming from a fan somewhere under the hood. It's definitly not the battery, it is new and everything else lights, radio, alarm and all else work fine. It seems like the car has developed a mood. I've been tokd it's the ignition or the starter motor that may need replacing etc. I'll try the trick with the battery cables mentioned previously..
However, If anyone has this exact problem and came up with a solution, please let me know,
Cheers
Vin
Old Sep 27, 2018 | 12:51 PM
tighed1's Avatar
Fan as in radiator fan or the little cooling fan in the black box next to the battery?
If the radiator fan,
check this out.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&u act=8&ved=2ahUKEwjthPmI0tvdAhVDXKwKHZpcCcQQwqsBMAB 6BAgGEAQ&url=https%3A%2F%2Fwww.youtube.com%2Fwatch %3Fv%3DE85akJMdmFo&usg=AOvVaw3CuFgglB3mHC9oMRB8rqG z
Old Sep 27, 2018 | 12:55 PM
tighed1's Avatar
If it's the cooling fan in the black box, sounds like it could be your relay control module.
Check this out.
https://www.crossfireforum.org/forum...-no-start.html
I can replace the relay that is causing the problem. Email tighed1@hotmail.com for details.
rorowland
16
May 14, 2018 06:01 PM
green-ghost
Jan 16, 2011 05:24 PM
old man
Dec 7, 2010 01:28 PM
tom2112
Oct 4, 2009 08:32 PM
Mike-in-Orange
Aug 25, 2007 12:22 PM
