My fog lights won’t turn off.
Old Aug 23, 2018 | 07:46 AM
Carlos99111's Avatar
Default My fog lights won’t turn off.
I have 2005 crossfire SRT-6 with almost 62,000 and my fog lights, side marker lights and tail lights won’t turn off. I have to jump start it or unplug the battery otherwise it drains my battery. My headlights don’t turn on. The turn switch is at the off position but they won’t shut off.
Old Aug 23, 2018 | 09:10 AM
Default Re: My fog lights won’t turn off.
How long have you had this car?
Is the switch in the straight up and down position?
On Canadian cars those lights are used as daytime running lights and are timed off by the trunk mounted security pump. I am not sure if they are all kept on after lights have been used at night on US car and the ignition switched off, I know the fog light is and it is timed out by the pump in the trunk, so a faulty trunk pump may be the cause. Rain water leaks into the trunk and wrecks the pump, check for water down beside the pump after removing the trunk mat.
Old May 21, 2019 | 05:35 PM
022008's Avatar
Carlos 99111 - i have had my Xfire for 11 years and this just started today. Anybody have any suggestions??
Old May 21, 2019 | 06:00 PM
Why ask Carlos, he never replied after 9 months, so we do not know if he got his solution or not.
Maybe you have water in the trunk around the CLP/SSM which controls the fog lights with the key out for ten seconds or so, any other lights on?
Old May 22, 2019 | 12:42 PM
022008's Avatar
Onehundred80,
your call was spot on. the unit was sitting in 3 inches of water. the lights have turned off, only to go back on and stay on. i take it i'll need a new pump.
would a new used pump need to be flashed by stealership?
Old May 22, 2019 | 03:03 PM
Onehundred80,
No it is plug and play. You can find them on eBay all the time.
Make sure you get one that has the plugs and pig tails, you do not want to use your old plugs as they will be corroded as well most likely. When you get the new pump you should try and clean the old plugs to see if they work, if not you splice in the new plugs.
It would be nearly impossible to just buy the plugs after you have got a pump. Good luck, it is not too hard to do, but find and fix that leak or you will be doing it again.
Old May 22, 2019 | 03:11 PM
022008's Avatar
It has been suggested that the water is coming in through the taillight. I'll hose it down with someone in the car.
Thank you for your help.
Old May 22, 2019 | 06:27 PM
The leak is less likely to be coming from the taillight, it is more likely coming in around the panel that has the spoiler motor under it, the joint between the gas filler cap and the fender or one or both of a broken or loose corrugated hose at the top of the tailgate where the wires for the license plate light and air line goes. On an SRT it can come through the same gasket around the spoiler mounting plate or the joint between the spoiler supports and the plate. Look for rust around the license plates lights. Also a poorly fitting seal around the hatch or trunk lid could be the culprit.
What car do you have?
airborne82nddiv2003
May 20, 2016 12:02 PM
MAYAman
Apr 12, 2014 12:32 AM
andyrouby
Mar 2, 2014 08:27 AM
krissysdaddy
Jul 17, 2010 04:38 PM
hmdixon72
Sep 16, 2007 01:29 PM
