Ok I'm lost!!!
Car cut off on me mid drive acted like it was an alternator, lights dimmed, wouldn't change gears out of first, ac cut off, kept dropping power then picking back up, dropping power picking back up, abs, esp, coolant and battery light all came on. Turned the car off at first it only clicked but wouldn't start, then shut that out wouldn't do anything. I've already had the RCM repaired.
Perhaps where it attaches to the firewall make sure it is a clean connection and I would replace the cable. It won't hurt anything and it may be an inexpensive fix. The cable may be corroded internally?
All that is good. I'm going to have the battery charged and check the alternator. I wouldn't doubt that it's the issue. I ordered one in as the other was rebuilt and is now out of warranty. I'll let you know.
For gods sake dont go all over the map. Get a voltmeter that plugs in the cigarette outlet and MONITOR the voltage while driving and having issues, CHEAP on ebay like 10$. Been saying this for ever..Woody
Will do and I appreciate the tip, but I'm also thinking that may not fix air leak I'm hearing from under the hood.
When I explain that, I get stuff like: "No, Im sure the alternator is fine..." or "a friend says it's my ignition switch..."
I think I'm burned out from helping people.
It was. The seal on the intake part that rests on the maf was messed up.
That is often cut and ruined.
jamespsnl
Jul 9, 2004 05:27 PM
