SRT6 Rear Alignment Specs??
Old Sep 5, 2018 | 08:57 PM
Turbo-Duck's Avatar
Default SRT6 Rear Alignment Specs??
Does anyone have the actual specs for the rear alignment?
I just added a pair of adjustable upper rear control arms, and would like to get it dialed in at an alignment shop. I was able to get it real close in my garage - about 1/8" toe in, and maybe a degree of camber. (Tire top in)
I'm thinking they should be Straight up and zero toe?
They adjustments I've done have already made a world of difference.
Thanks in advance.
Speedway parts - Upper Control Arms.
Old Sep 5, 2018 | 09:42 PM
CROSSFIRERUSH's Avatar
Default Re: SRT6 Rear Alignment Specs??
Here ya' go...per Chrysler:
WHEEL ALIGNMENT
DESCRIPTION
SPECIFICATION
Vehicle level - front axle1.4° (-2.1/+1.4)Vehicle level - rear axle0.4° (±0.8)Ball point position30.5 ±2 mmFront axle toe-in0° 20'±10'Front Camber-1° 13' (-1.22°)Front Caster5° 12' (5.20°)Toe-out on turns with wheel on the inside of the curve steered through 20°-1° 25'±30'Rear Camber-1° 08' (-1.13° ± 0.5°)Total rear axle toe0 ° 33'±7'Permissible difference in front axle camber between right and left side of vehicle20'
Regards,
Old Sep 5, 2018 | 09:44 PM
Turbo-Duck's Avatar
Perfect - Thank you.
boostmonkey
18
Jan 22, 2014 03:19 PM
cjw
Mar 6, 2012 10:49 AM
boboridesbmx
Jan 25, 2012 05:46 PM
klong
Feb 2, 2010 01:32 AM
jayf
Dec 26, 2006 01:30 AM
