Dash code that is not a "P" code... what is it?
Old Sep 11, 2018 | 04:48 PM
Luthier's Avatar
Default Dash code that is not a "P" code... what is it?
Hi, Everyone! Just bought a 2004 Crossfire Coupe with 26,000 and some change on the odometer... and still has the original tires! (Yes, I'll be changing them soon!) So can I join your club now!?
I've tried searching for this problem... but when you don't even know what to search for, you don't get very good results. :-D
I'm getting a code at startup in the odometer area. NO Check Engine Light that stays on, all lights come on and go out in seconds, as they should.
But there's a graphic symbol that looks like maybe a clock face... or a pie with a slice out :-).
This is followed by another symbol, which may or may not look something like a bird's wing or a swoosh with a couple of scallops in it.
And finally "- 628" is displayed. This stays displayed for maybe 10 or 15 seconds and eventually is replaced by the current odometer reading.
Has anyone any idea what this indicates? Thanks in advance for any help or information!
Old Sep 11, 2018 | 05:38 PM
Default Re: Dash code that is not a "P" code... what is it?
That sign indicates the time for an oil change if it was done correctly, That sign is reset every time an oil change is done, it resets to 7,000 miles I believe. The minus shows up after the 7,000 miles has passed or it means you have 628 miles until an oil change is due. I am not sure but someone will say exactly if it is a before or after number.
It is a new car to you so I would change the oil with Mobil 0W-40, set the FSS sign to be sure it has the correct oil in it and it has a known mileage on the oil.
You can down load the Owners Manual from this site, it is in the Documentation thread. CLICK
Old Sep 11, 2018 | 07:33 PM
Luthier's Avatar
Thanks onehundred80. I never would have guessed that middle symbol represented a wrench! :-)
The Trip meter displayed 76xx-something, but I didn't make the connection there. Fiddling with the buttons, I had managed to reset that to zero, so I'm glad the system kept track of the overage on the miles.
I see in the manual now how to reset that code. So now I just have to get some oil and a filter and go have some fun!
maxcichon
Site News
16
May 26, 2012 09:20 AM
offshoreMM
Jan 2, 2011 12:58 PM
holgo123
Feb 7, 2009 05:57 PM
+fireamx
Other Cars Etc
26
Dec 13, 2008 12:54 AM
