Coolant level in reserve/overflow tank
Old Nov 21, 2018 | 06:57 PM
Jim Holian's Avatar
Default Coolant level in reserve/overflow tank
Just doing normal underhood cleanup and maintenance, I took the cap off of the res./overflow tank. I see there is coolant in the small chamber of the tank. The chamber towards the firewall. According to the shop manuals that I have, the coolant should only be in the larger chamber which is in the front of the tank. There is a white peg that sticks up in the smaller chamber, the one that the manual says should be empty, and the coolant is at the top of the white peg. The coolant is clean and has the proper green tint for antifreeze. I'm not having any cooling issues but I'm concerned that there is fluid where the book say's it shouldn't be. I don't want to do any damage so I thought I'd ask if any of you have the same situation. I don't smell any antifreeze so I assume that I'm not losing any. I welcome any thought's or opinions you may have. Is this fluid in the smaller tank OK and not capable of doing any harm?
Thanks in advance,
Jim
Old Nov 22, 2018 | 10:26 AM
Default Re: Coolant level in reserve/overflow tank
Thanks in advance,
Jim
The top of the white peg is the height that the coolant is filled to. So how could you refill the system when you cannot get to the other tank, the one you say is the only one that should have fluid in it? Why would they put a filling cap over the tank that is supposed to be empty?
The larger tank is the overflow and makeup tank, the coolant flows back and forth between tanks as the temperature rises and expansion takes place. SRTs have three compartments I think. My SRT tank ( Mercedes part # 170 500 05 49) looks to be full in all compartments. Any excess coolant gets blown out the rear hose coming from the neck of the filling cap, the excess coolant causes the cap valve to lift just like a old time radiator cap.
I think you have misread the Service Manual.
The NA tank is Mercedes part # 170 500 03 49
Old Nov 22, 2018 | 01:16 PM
ROB311952's Avatar
I've always just kept the level right over the top of the white bar/peg in the tank and it does fine that way.
Old Nov 23, 2018 | 10:31 AM
Jim Holian's Avatar
Thanks, Gentlemen, for the information. Now I'm comfortable with what I see in the tank.
Jim
lslajohn
Apr 30, 2018 07:44 AM
JesseJamessrt6
Jul 17, 2013 09:36 AM
goodgenes79
Dec 16, 2012 10:28 AM
NeverEnough
Oct 20, 2007 08:12 PM
ColoradoXFire
Jun 24, 2007 07:31 AM
