Is factory amp still active in my 2004 after installing an aftermarket radio?
Old Dec 5, 2018 | 07:54 PM
Mdcrossfire's Avatar
Default Is factory amp still active in my 2004 after installing an aftermarket radio?
My factory radio was missing when I recently purchased my 2004 Crossfire. A great local audio store installed a fabulous Kenwood radio with lots of graphic equalizer settings, SiriusXM direct tuner added, and Bluetooth that works like a factory unit! They used the original factory connector to install it. My question is, is the original factory amp still active with this type of installation?
Old Dec 6, 2018 | 12:34 AM
dinasrt's Avatar
Default Re: Is factory amp still active in my 2004 after installing an aftermarket radio?
Maybe, probably, depends on how they wired it. Or how the previous installer wired it. Check out the "Stock Amp is 4 Channels" thread. At the top of our forum home page is "Search"; It is between "New Posts" and "Quick Links". Click on that and type in Stock amp is 4 channels. It is very informative. You could perhaps bring the schematics to your installer and ask him about it.
Old Dec 6, 2018 | 12:35 AM
JSK's Avatar
JSK
If the installer didn’t do any wiring modifications it should function like stock.
Old Dec 6, 2018 | 12:52 AM
dinasrt's Avatar
Yes, but it's sure nice to modify the wiring and have the 4 channel function, instead of stock 2 channel.
Old Dec 6, 2018 | 05:59 PM
Originally Posted by Mdcrossfire
A great local audio store installed a fabulous Kenwood radio.........
The Kenwood IS great, as is JVC. Anything else is low class crap.
But most "great" audio stores employ minimum wage, part time, high school or college kids as installers. Who knows what they did.
If you got the "free" install, or the usual $20 install, they took only fifteen minutes to install it.
JSK's seemingly non-answer is the only answer anyone can give - cause we don't KNOW what they did. Ask THEM what they did, and if they act like they are not sure - well, that's why I install my own stuff.
Old Dec 6, 2018 | 08:33 PM
OR, you can take out the access panel and see if the amp is bypassed? Might help to see that at the amp location.
Old Dec 7, 2018 | 02:19 AM
MAGNATUDE's Avatar
If the great local audio store used the original factory connector (possibly incorporating an MBZ aftermarket radio wire harness), it is most likely the original factory amp is still active. ...yes
Should have been a quick and simple deck only install.
If no one else have mentioned this to you; Here's a TIP: Keep the radio removal tool in a secret place in your Crossfire. You will need it again someday, unexpectedly.
dpbayly
Dec 14, 2015 01:34 AM
Vipor3D
Dec 27, 2012 12:57 PM
theoneandonly
May 12, 2009 09:09 AM
Irafatsar
-C-I-C-C-I Discussion
30
Oct 15, 2006 08:01 AM
FarbenKiber
Nov 23, 2005 02:47 PM
