LED Headlights
Old Jun 12, 2019 | 06:26 AM
ardenian's Avatar
Default LED Headlights
Has anyone had success with LEDS in the Headlights? I was just wondering if modern technology had improved them. My car has had an HID system on it from me buying it, but in the UK they will fail the MOT. I was just looking at alternatives and thought reduced heat and wattage from the lights might be a good way to go.
Old Jun 12, 2019 | 10:36 AM
Default Re: LED Headlights
I have Morimoto 2stroke H7 LEDs in both high and low beams, works great, little heat, no amps to speak of and color and brightness are the best I have ever seen.
I had Morimoto HID's in the lows previously.
Old Jun 12, 2019 | 10:56 AM
I think HIDs and LEDs will give more flare than normal bulbs because ideally the light source should be at the focal point of the parabola.
I had a low cost HIDs in my lows at one time, I have forgotten why I took them out. Nice and bright but l never put them back.��
Old Jun 12, 2019 | 11:24 AM
ardenian's Avatar
ala_xfire are they either of these, and did you use 4 the same for bothe headlights and did you need canbus decoders also?
Old Jun 12, 2019 | 11:40 AM
They look good with the light source presumably where it should be.
Old Jun 12, 2019 | 12:39 PM
They are the lower gold ones, and I did not order the CANBUS, my light is on full time anyway.
Never been able to find out why, changed every bulb at least twice.
Old Jun 12, 2019 | 01:19 PM
cg80's Avatar
Hi
George. Just wondering why you went to LEDs instead of the HID.. I have HID and they seem to work fine?
Old Jun 12, 2019 | 01:55 PM
Originally Posted by cg80
Hi
Cause I'm a cool and modern dude !
Have to keep up with the baby boomers and millennials.
Old Jun 12, 2019 | 03:09 PM
Keeping up is hard on the knees and hips at our age, I would be satisfied just keeping them in sight but the bad eyes prevent even that.
I reread your post so I edited what I had written, we need the canbus then?
Those lights look pretty good, is there anywhere on here that shows the setup?
Old Jun 12, 2019 | 04:13 PM
CANBUS:
I do not know if the CANBUS is necessary since my light is on anyway, but I can conclude from the fact that a CANBUS option exists, it IS necessary.
SETUP:
I had promised someone ( can't remember who ) that I would do a write-up on the install, but got lazy, then got forgetful.
I'll put it back on my agenda.
James1549
May 31, 2020 09:24 AM
maxcichon
Jul 8, 2016 08:28 AM
AEROSRT6
Jun 30, 2015 01:59 PM
jonctovar
Aug 3, 2014 02:20 PM
bluemax
Dec 31, 2012 04:19 PM
